13 hours ago, Beyond Blue R33 said:
Thought I had died but only fell asleep watching the welding arc. What's the new job dale?
Well YOU wouldnt let me have a crack at your drawings, so I decided to find someone who will :D
Funny thing is, I decided to try and go back to designing, and had my spine immediately shit itself and flop me into a surgery with little to no warning. Turns out, that exact same day my name popped up in a conversation between some old colleagues, and they rang the Good Wife to get me to attend an interview.
When the mrs told them I was currently opened up like Skywakers Tauntaun on Hoth they said they were THAT fkn keen they would see me any time I was ready (?) so I decided (while still off chops on meds in hospital) that I only needed 1 week to get over spinal fusion and I was bang up for it, and now tomorrow morning I will be in my best shiny bum costume in the cbd...
  • Like 1
On 12/5/2017 at 2:45 PM, Stinky Rooster said:
oh lawd, and so it begins...
...Murica'
You know it moite!
Talking to multiple people trying to source a car, this is the latest offering, but it's about $3k USD over budget. It does have the later 6.5L engine though.
Car is in Arizona, only one state over from Cali.
  • Like 3
Hank - all it needs is a confederate flag on the roof, and twin 10' stacks = sorted
Tits - Yup. Lost a bit of weight since the old days so I doubt the old ones will fit. And nobody wants to see loose fitting arseless chaps
no one
  • Like 1
Deep water fording kit! Hank would fkn love it!
HMMWV_deep_water_fording_training-300x20
Well YOU wouldnt let me have a crack at your drawings, so I decided to find someone who will [emoji3]
Sorted. Beep,beep,beep reversing in the door. First impressions.images (3).jpegimages (2).jpeg
  • Like 2
  • Haha 1
Skyline has gone to its new home ? gd news its going to live on! The guys got a rough shell the same colour that hes gonna huse the front end off to repair mine as the bodys in much better nick!
  • Like 2
Skyline has gone to its new home [emoji17] gd news its going to live on! The guys got a rough shell the same colour that hes gonna huse the front end off to repair mine as the bodys in much better nick!
?‍♂️ x
Friyay ! Morning everyone ?[emoji485]
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
