No much worse, an Oil & Gas company that never stops production where every day lost is over $1m in revenue
Got the 3 days between for 10 days off. Have beaten the 2nd week of Jan deadline by 3 weeks yeah. Quoted 120hrs on job for Jan and got the job. Quoted 260hrs for another job in Jan and got the job. :-o hope the couch can handle 10 days of my fat arse on it. Do you want ham in those toasties, ham and salad roll, ham and ham with ham on the side?
  • Like 2
10 hours ago, turboedsloth said:
Going back to doodling Dale?
am already back doodling, thank fk
Still trying to get over the fact that they replaced the automatic espresso machine for a fkn pod thing
A FKN POD THING, PEOPLE!!!! THE REVOLUTION WILL NOT BE TELEVISED!!!!!!!
  • Like 1
We almost did that at work too!
  • Like 1
All modified skylines have coffee pod filter. Froths up the oil into the catch can and pcv valve for a sweet fuming blend of 7.5/35w. need a fmic for the one at home. Has been a bit sluggish lately?
  • Like 1
coffee pods are the devil. They have the WORST coffee in them - the one at work actually trys and uses the fact that it has robusta beans in it as a positive :cry:
Plus, the stupid amount of packaging waste they make is one of the things the next generation is gonna be pretty pissed about, and I cant say I blame them
Green pods are people.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
