IMG_2227.thumb.jpg.6ffb113aec7b9a95669074f759c650a1.jpgIMG_2286.thumb.jpg.fed3c3425a6ef6b4041817ff45a91208.jpgIMG_2284.thumb.jpg.5275d12b4b0d77f9002fafe6f230819b.jpgIMG_2282.thumb.jpg.30d3c68bef6802152a8556eae3bf1200.jpg
Eye candy for you boys !
Bought my spare parts for $250 AUD !
Back home Josh wants $1700 , Nissan’s $2200 and I paid 26k Yen ! So how much is that in AUD [emoji23]IMG_2274.thumb.jpg.217186a957d4d861c9910139fbfb6d51.jpg
So jelly your in Japan [emoji627]
  • Like 1
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday short as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
We Catching up with few friends today , to take him to the hospital.
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday shorter as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
Bugger hope he gets better soon!
  • Like 1
my xmas bonus was being asked to come back on the 2nd instead of the 8th........
ahh the life of the scumbag mercenary contractor, how I have missed you.
Doc has laid down the law that I cant get back on the bike till march, so I'm now getting full on planning for some mods, looking for opinions.on direction
flat track / rat racer
01.jpg&key=72f68c476db4e391d7a695be159d6aaf4b03c9121ce37f7ae802c9ece5a0ba6a
street scrambler
a7d552e1562733cbd548e9a76627ad83.jpg&key=ecc28356e4160e961950450d6f8bc0e5ff73227f6055a2f8f411ff9a434824ff
or super motard
a87da3efdde383267a7c21b157470137.jpg&key=c449d6a03ae32ce1bed76d04d44ba42c2f796e9e6cca5edaa02516c688fea7c9
thoughts?
The weather is nice today would be my current thought. My one before that was how much I was enjoying my sausage rolls for lunch.
Jam a couple tampons up there [emoji12]
  • Like 3
Bummer Dave. That sucks.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
