5 hours ago, Beyond Blue R33 said:
On a separate note I thought you might like this kieran, Nihari slow cooked beef curry/meat stew. 2kg 2" thick chuck with bone in. 1 kg of beef bone pieces. 6 hrs on the hob covered. I'm about 3 hrs into it. Got garlic naan and some bassmati rice. Garnishing with green chilli, and some julienne ginger and lime. emoji848.png
Now your a pro, come do mine!!
Above 100 so many whistles
Came up pretty tidy. Just won't start now. F##k. Previous owner was a whizz with electrical knots and loose tape. Will be central locking to immobiliser. Going to bed. :-( DSC_0170.JPG
Feb 16th this friday turn up that boost controller at barbs !!!
Members tuning day 1st one for 2018.
You'll need cams lic which pays for it self if you have shannons insurance 10% off your total ! and then become wascc member first day is free.
I'm going regardless not worth doing it back streets.
Hit 3 pink galah the other week in 3rd gear at full noise.
Could have been worse a gumtree or a child.
So im releasing my energy on a track
Got a mate coming too with his new r32 as well [emoji4]https://www.wascc.com.au/events/
Hey dude how did you go out at barbagello? [emoji23]
It was really fun :D car was a pig untill tyres warmed up then she was spastic.
Got a bit worried about my water temp on PFC 103 was the max so im not sure ?
But i was happy :) overall had a photographer come out aswell his 1st car shoot so was a challenge for him but he had the gear i must say had a big $ white lens $
looks like my back yard about 3 minutes after I got my first dirt bike in 15 years [emoji3]
Spinning out stumps one tyre at at time. Re-alignined the windows. Re-wired the central locking back to the immobiliser. Tidy as.[emoji41]DSC_0170.JPGDSC_0174.JPG
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
