Good turnout last night, some real head turners too!. I took some photos but they're still on my camera, will upload later.
I drove through on the way home at about 8 pm seemed to be pumping still, was in the 4b so wasn’t going to stop
  • Like 1
Yeah @z00keyand I left at 7:30 with Avo. Avo and I went to another meet in the city after. Was a long night.
  • Like 2
Dugite
Found it’s burrowed under the shed. I couldn’t coax it out. Hopefully it takes off tomorrow
Propane torch down the hole. Don't f**k around when it's near the wife and kids. Kill it.
  • Like 1
Went for a swim in Dave's pool in Kalamunda on new years. Thomas thought I'll do the right thing and help clean the pool. Baby dugite. He thought it was a stick. Ditched it from the pool. Lucky. The immature snakes don't control their venom and just unleash a full squirt.
It’s burrowed under the slab far enough that it disappears. My sea container is up against the shed leaving a small gap to see it moving.
I’ve read about using minnow traps to catch them. I should be able to see a track if it leaves but
not wanting to be a prick. but you know thats actually illeagal, right?
  • Like 1
Spiders ftw!
Check it out. 6 from 12 studs snapped under ring spanner back and forth careful arm pressure.centre popped and easy outed all fully drilled, tapped and ready for new genuine nissan studs washers and nuts. The manifold was so warped it was ridiculous. It's in being Re-faced now. Butter bolt studs and rattled up I reckon. Madness.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
