And that's why we all love Hank!!
I take it the shopping spree means the offset is going well?
I am looking at Kamodo's at the moment. Too much weber love to go for an offset, but there is always room for expanding the fleet, amiright?
even I cant justify spending that much coin on a bbq, or the big green egg would be a dead cert!
In other news, John Harvey Kellog, the guy famous for inventing breakfast cereal, also invented the health sanatarium, the electric blanket...
...and a machine that could fire 15 GALLONS a minute of water up your backside, and if you were unlucky enough to undergo this treatment, you could look forward to it finishing up with a half gallon of yoghurt going straight up the newly cleaned colon....
lulz
The new bloke from Tasmania who started here last week called the boss this morning to tell him he was sick and couldn't come to work.
The boss told him "Mate, we are flat out here, and really need your input on this quote. How sick are you?"
Tasmanian mate replies - "Well, I am in bed with my sister..."
That reminds me - we need to plan another playdate for our boofheads. We have a brand spanking new dog park just behind us now, with 3 separate fenced off leash areas.
Every time I take HRH Princess Blossom Pops down there, everyone else bails to one of the other areas and we end up by ourselves - its fkn awesome
For sure!
What is it about 2, large, black individuals that make people run away? :P
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
