If any one needs 2 18” tyres to suit skyline I have 2 Michelin Pilot Sport 3 PS3 245/40 ZR18 18” tyres I need to get rid of, $200 cost $500 they are still like new as we had them on the front but they scraped on the guards so we removed them.
That's shit Martin, sorry mate.
In other news, Wu Tang is coming to Sydney in December and playing the Opera House, so you all know where I'll be on Saturday December 8!
they not coming back to Perth? One of the loinspawn was there when ghostface went to the sammich shop. Apparently it was off chops.
Still not enough to make me want to go to Sydney though
That would have been wicked! I went to that gig at metros which he was there for (I believe Pharoahe Monch) was at that gig too.
Nah, not coming to Perth, only going to the Opera House to play a 36th Chamber 25 year anniversary show, here's hoping they all get Visas this time...
you aren't going to steal my idea I hope.
I don't have much on this weekend either. Reckon Hank could handle a house guest? Still haven't seen the offset in action.
Not so fun day at barbs on friday. 20180706_110245.thumb.jpg.e163304d5242ecc84e68b4788ea69487.jpg
:O That looks expensive.
what went pop?
Dipstick popped out?
Yer oil dipstick popped out too much pressure in crankcase.
Not sure to why i had so much pressure to do that. But to fix the problem and do happy track dayz i think i need a catch can, larger sump, baffle kit for sump n cam cover, oil restrictor Maybe even a oil accumulator on top.
Then it might hit the track again but for now ill keep it straight drag pass.
Did loose about 4ltrs of oil from 6 hardly touching the dipstick that how known something went wrong as i was going up the shecane at 6k to 8k rpm i look down n noticed oil pressure at 2kgcm2..... at that point my car seat had me by the balls.
No knocking but at idle in gear lift the clutch put load on engine makes a small squeaking sound n crank pully has very slight movement . So thrust bearing has worn too much. :(
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
