1 hour ago, t_revz said:
Sudden urge for sashimi
I actually ate raw fish for the first time a couple of weeks ago, it was farken tits!
Sushia in Brookfield Plaza - solid tip for Japanese fine dining.
I fkn love the stuff. I could live on it
oh lawd I love the internets
http://www.scottmorrison.com.au/
PM forgot to renew his domain, it has been bought out from under him and fkd with
  • Like 1
2 hours ago, Stinky Rooster said:
that's pretty fkn exciting.
and probably due in no small part to those lunatics @ antilag.
Onya guise!
Yeah, old mate Buckets had much to do with it.
We might have to do more Motorsort roadtrips mate!
The Humvee is getting closer, we will be cruisin' at 95 km/h in no time lol
95? That's a bit optimistic don't you think?
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
