On 1/26/2019 at 9:06 AM, t_revz said:
Happy invasion day bishes.
Hope it warms up to help the beers go down
In honor of our indigenous folk, I spent invasion day listening to the blues
Your welcome, unna.
  • Like 1
1 hour ago, Hank Scorpio said:
Dude, those pork ribs we had were next level.
We need to do a massive cook up in the cooler months. Brisket, beef and pork ribs, sausages.
I am down like an extra chromosome. A WT feed like days of yore sounds like an epic idea
and yer, best ribs I have ever sourced. Sooooo meaty!!!
Melville Heights Meat for those of you playing at home. The main man Ian is a god of all things meat, and if you are looking to source restaurant quality cuts to impress someone, you cant do much better.
In other news, my first attempt at a sourdough came out way better than I expected.I kinda screwed the pooch at the end getting the final shaping right, but taste, texture and proving my starter was right came out spot on.
The perfect wasteland accommodation on your next trip to Belgium.
http://verbekefoundation.com/en/slapen/casanus/
Cas Anus. Only 120 euro a night.
  • Like 1
  • Haha 1
Equipped with lightening
Does that mean it makes you skinny? Or you can strike ppl down with 1.21 jiggawatts?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
