It's a split hose!!! I found the leak. The question is, how do I change this hose? I'll put some photos here.
It's a very small, short hose at the rear center of the engine.
Any one know which hose this is and the best way of tackling it? (from underneath or above?, tips?)
http://imgur.com/a/OkvpU imgur flipped the photo, no idea why.
Put your pics in the thread not link as I find it pain in arse to leave thread then come back (3rd world probs i know)
huge photo is huge, but yes, that's the hose causing all the trouble, it's just out of reach from the top.
I'm going to replace it with a silicon hose, but I'm not sure what size I need, and how to remove it.
Edited by Manne
I saw that breakdown but it's all moon-speak to me. I've read a few threads on coolant leaks in that general area, and it looks like it's going to be a bigger job than it looks, a real knuckle scraper.
The cars not yours till it has drwn blood [emoji6]
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
