1 hour ago, Beyond Blue R33 said:
Post some pics when you've finished? The work you have done sounds top notch. Wouldn't expect anything else after seeing the engine fit and engine bay pics. You're a animal!
quick diagram of it. the only thing that isnt complete is fitting the ducting from the ceiling enclosure to the bedrooms. i was thinking about using 100mm stormwater pipe to each room but now im after 100mm steel piping to use instead.
  • Like 1
Insane. The tubing system should be 0.7mm s/s crimped and swaged. Dual 45* off the main flu would be better than a 90* t piece for draw. If it's running off at 90*. A dogs leg in the insulated flu section would help the heat stay downstairs and run off to the rooms better. The storm water pipe would melt and should never be used for this application off a wood heater. 0.7 s/s crimped and swaged inside insulated through the walls and roof. The storm water pipe would only be good for a reverse cycle system and is totally inappropriate for a wood heater.
when i tested last season the enclosure temp was only 40C max. now that the bottom section isnt insulated the temp is much higher and i have to change to steel.
where can i get 100mm steel pipes at a reasonable price? think gutter down pipe is only 70mm.... flue piping is probably too expensive....ideas?
We have m.s.t. and s.s.t. at work it's 101.6 mm o/d (4") and 1.6 mm or 16# thick (for exhaust systems) 70mm would be 2 3/4" o/d. And the same thickness. Most stuff to do with heating and flues is 304 s/s 0.7mm thick because of its heat transfer properties. We sell it by the metre in s/s and m/s at work (the 16#) If you know what you want and let me know will be cost price:-) or Jarrahdale heating and cooling or perhaps kounis metal industries have the crimped lapped and swaged 0.7mm at God only knows what price. Will post a pic of the 0.7 crimped and swaged from my heater.
cheers, a rough price on mst 4" would be good thanks. no idea how much i need yet but say 20metres at a guess
just found stratco sells zinc downpipes in 10 different sizes including 100mm. i dare say it will be pretty cheap as its so thin 0.4 or 0.5mm
Perfect would be way cheaper than s/s or a heavier guage. The zincalume will last for ever indoors.
Maybe just get one length check how hot it gets? you could lag it where it's near wood gyprock etc. With needle felt fibre glass or the fibreglass roll tape stuff. Or anything else that is itchy. Man I hate lagging stuff up.
due to smaller ventilation holes to the top, plus the top section being an insulated flue the absolute max i would expect coming out of the enclosure is 60C and could possibly be only 50C. id rather have metal pipe from the enclosure down to the fans but it shouldnt be that hot that i need to keep it away from timber etc...
as always i test very thoroughly and i will know the actual temp next days off and build it with a higher than actual temp spec in mind
yeah i thought it would prob be cheaper. thanks anyway
Salvage yard if stratco arent cost effective?
What about the silver foil backed stuff for under metal roofing?
On 5/12/2017 at 1:47 PM, colin.ssc said:
@Hank Scorpio recommended camber arms brands? Thinking of getting F&R set for the 36 but not sure if the cost of getting it is of any benefit lol
I like Japanese stuff, Cusco and Kazama are always good.
  • Like 1
https://www.bunnings.com.au/earthwool-r-1-3-55mm-18m2-space-blanket-under-metal-roof-insulation_p0810887
This stuff, would just need to use foil tape to seal it around the pipework.
Looks very itchy so would do the trick.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
