Hi All,
Wanting to know if anyone has direct experience/ knoweledge on pon-cams..
Specifically if PN# 143021 264/264 duration 8.5mm lift will run in an rb20/ r32rb25de head?
They are listed as suitable for R33 rb25det up until '97 manf date.
But confilcting info on the web is rife and i cant find a clear answer.
- Some say theses cams aren't compatible with VCT in the rb25dets that they are listed for.
(Thus making them quite suitable for the rb20dets).??? this may be BS??
I am looking at these cams for my rb30det build (using r32rb25de head), but not sure if these
would be compatible with CAS etc.
Thanks for any help-
https://www.sau.com.au/forums/topic/456976-tomei-pon-cam-question/
I don't see the headache...
Just need to know if anyone has fitted poncams that are supposed to be for r33 rb25det's into an rb20det?
You need to sit back and realise what you're asking.
First you say you're building an RB30DET using an R32 RB25DE head and want to know if R33 Poncams will fit. Then you're asking about it going into an RB20DET.
What do you want to do? Put the cams in the RB25DE head or RB20DET?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
