Say what?!
if they have -11 at the end then all you have to do is gap them down to 0.8.
If they are the same heat range as what is required then it makes zero difference!
I have gotten spark plugs that were meant to be gapped at 0.8 but were all over the shop, 0.7 - 1.0 on a batch of six
Far out that's shitty consistency (0.7-1.0).
I was just being lazy.. pregapped is less work. But if they are so variable with the gap then yes you might as well get the 1.1's and gap them down yourself.
So Iv put the new splitfires in turned out the drama was a 10 mm bolt half under the coil yes I should of checked first which I wouldn't think it would be a simple fix but it was $$ who knows what else the previous owner has left me.. ebc is in throw it at the dyno for a safe tune next
  • Like 1
You'll use the splitfires anyway............a step up from OEM and good for extra boost - when you get that bigger turbo and start huffing!!!
And I'm sort of surprised nobody mentioned taping them just to check it wasn't an arc issue???
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
