Hi all, have had a quick search but with little to no luck.
I'm just after the diameter of the inlet and outlet of the cooler core so I can grab some more silicone joiners before I head off and grab some more tomorrow.
Cheers, Steve.
https://www.sau.com.au/forums/topic/457392-3233-gtr-intercoolers/
Pretty confident it's 80mm not 3 inch, I know the engine end is 80mm. Japan don't use imperial at all afaik.
3 inch will stretch over 80mm but it's a pain in the arse. Better to just get the correct size.
Silicone will help it slip off too. I want to use Tarzan grip on mine to stop it leaking at 32+
80mm is easy enough to get these days.
Use hair spray. It wont go anywhere
Ive also stretched 3" onto the intercooler, but sounds right that it would be a typical jap 80mm (3 1/4")
Cos I'm picky, the Japanese do use bsp so yu r rong. Take that .
Why change what works, if it wasn't for the bloody US it would probably be a world pipe standard.
Pretty sure they had laws against using imperial, as did Australia.
  • Like 1
Um.....BSP is Imperial. The very definition of Imperial. It's just different Imperial to the NPT Imperial. As long as we're using "Imperial" to mean "based on units which are based on the length of some old codger's thumb".
BSP has become metricised, but the sizes are still exactly the same old inch bullshit they always were.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
