I'm having an issue finding out what starter i have. This starter came with the motor set when i bought it years ago, since then starter had been giving me problems, had it rebuilt but its still acting up.
I'm trying to find what other starter i can use that will match this starters dimension since i'm in the USA, if unable to locate id gladly locate it internationally as well so i can get the car back on the road.
Motor R33 RB26, Trans RB25
Today i had an electrical repair shop give me this starter to try however the nose is way too big and hits the trans housing.
Here are some pics, what i have been able to identify on old starter part number is 23300-20P05 (i think its missing numbers after 5, perhaps 51 or 52?)
https://www.sau.com.au/forums/topic/457848-rb-starter-problems-please-help/
Firstly, that part number format is correct, it is xxxxx-xxxxx so there is no digit missing.
Starters are not normally a problem in Oz because all of the RB motors (RB30, RB25, RB26, RB20) all use the same one, as well as a locally built holden shitbox. They would also be readily available ex japan, but I have no idea what common US car would use the same.
Gents I would gladly buy a starter out of the country as long as I know of a reliable unit that will actually fit, if no part numbers are musing from my label (first picture) it makes 23300-20p050 does anyone have an actual year/make/model that this ties to? Google came up with nothing :(
It def has to be the same dimension as the part of rb25 wont accommodate anything longer, such as ka24 I attempted to install today.
Thanks for everyone's input!
Hi mate, just recheck your pic, it shows 23300-20P05, not what you posted above (-20P050).
You could always buy brand new from amayama but ouch! US519 https://www.amayama.com/en/search?q=23300-20P05.
I don't know how to reverse search to a model, but your number matches an R33 GTST VIN that I have. It has an alternate part number 23300-AA300 which will be a direct fit, and another part number 23300-08U15 for a different "specification"....my non-existent Japanese wont let me work out the difference
Anyway, all that aside, if you are happy to buy from Japan just contact Jesse Streeter and tell him you need a starter motor for an RB25 he'll come up with new and 2nd options for you.
Thanks mate!
The label on my starter is old so the numbers wore off but I'm happy you verified correct part # -20P050
Also if direct cross reference is part # 23300-aa300 I have seen those float on eBay from some U.S. Sellers 2nd hand and will give them a shot as my unit is completely toast :(
This part # 23300-08U15, would this fit also or it's totally different? Thanks for the referrals where to obtain them I'll try them out in event I cannot locate them stateside.
Tons of thanks for the info!!
just found this one in the states, 23300-AA300, looks just like the 23300-20P05, however since this is a large wholesaler they were unable to send me front picture of the unit to see if its exact same as mine, looking at photo comparison looks almost identical, fingers crossed that this works!!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
