THE ULTIMATE STREET GTR 10sec street car
FEATURE CAR IN HPI VOL46 CURRENT ISSUE IN STANDS NOW
NISMO LM WIDEBODY only 1 in Australia
built, tuned and maintained by one of the best tuners in the racing circuit here and overseas.
only done 14500 km after build.
Twin KKK Top Mount Turbos rated at 900hp
Blitz Manifold
Twin External Wastegates
88mm JE Racing Foged Pistons
Hks 280 Cam Shafts IN/OUT
JUN Cam Gears
Hks Drag Pro Valve Springs
Modified Headwork
Balanced Crank
Short Pin Rods
ARP Rod Bolts
Nismo Oil Pump
Nismo Water Pump
Nismo bearings
Custom Catch Can, Braided Hoses
Hks oill Cooler with remote filter
Os Giken Twin Palte Clutch
custom 4" stainless exhaust
Twin 3" Stainless Steel Exhaust system( as a spare)
55mm Tial Racing Blow Off Valve
120mm Blitz Intercoolerand cutom piping
Custom stainless induction, k&n filters
Motec Ecu
Twin Bocsh Racing Fuel Pumps
Custom Surge Tank, All Braided Lines
Custom Fuel Rail
900cc Injectors
Sard fully adjustable Fuel Regulator
ngk Iridium8 racing spark plugs
Motul 300v
Hks EVC5
Tein Coilovers
Nismo White Dash And Cluster
Recaro Drivers Seat
18x11 3 Piece Equipe Racing Wheels Allround 275x35x18 Falkens
Endless pads
Air Conditioning ( re mapped )
Full Alarm System
Sony Cd with remote.
power
500@4wheels@1bar on optimax no aditives EVERY DAY DRIVING
561hp@[email protected] on optimax no aditives EVERY DAY DRIVING
650hp@4wheels on race fuel. IF YOU REALLY WANT IT.
this is a seriously IMPRESSIVE and FAST CAR..
will run 10sec
ran 11.7@122mph on just 14psi soft launch. optimax in full street trim
only ever raced once. used everyday.
replacement cost over $100000
FOR SALE $75000
will consider trade.
will consider selling all performance mods as a full package inc motec ecu,clutch,intercooler in the lot, just put in your gtr and you will have a bargain.
$30000.00 plus your standard rb26 engine.
will also consider selling widebody without the mods and engine setup for $45000.00
so if you want a well built no expense spared supercar.
Genuine Ineterests Only Please. sms 0404134400
https://www.sau.com.au/forums/topic/45815-widebody-gtr33-800hp/
You are going to get 1,000 posts asking for pics, just post them to save yourself the pain.
p.s. How much fuel pressure does it take to get 720cc injectors to pump out 800hp?
p.p.s BUMP :cheers:
p.p.s BUMP :)
ALL PICTURES ARE IN HPI VOL 46 IN NEWS AGENTS NOW.
THANKS.
Hi there,
Are the cams 280 duration on both intake and exhaust and also what lift are they.
Can it make more HP on racefuel or you havent takin it that far yet.
280 cams on both sides.
not run on race fuel. this set up will make 600+ hp @4wheels easily. if you see the pictures and the article in hpi vol46 you will see what i mean.
ran the car on 1/4 for 1rst time, low boost run 14 psi @11.7@122mph
full tank fuel, street tyres, aircon.
look forward to a 10 sec 1/4 next test an tune.
lol sorry i forgot all about this topic.I have a few more questions for you.
1)Hows this thing on the street with those size cams are the ok or are they bordering ridiculous???
2)Does it run hot with cams that size as ive been told something with that size duration cams always run really hot.
4)What size lift are the cams?? are they the 10.? lift ones or the 11.? lift ones.
5)Whats the usuable rev range on these cams for both street and track.
6)Whats the compression ratio of the engine I can gather your running some high comp ratio...say 9-9.5 to 1.
7)What exact Motec does it have and do you have any under bonnet pics.
Thanks.
FOR SALE FEATURE CAR IN HPI VOL46 CURRENT ISSUE IN STANDS NOW
Car Specifications JGTC STYLE WIDEBODY WHITE WITH RED PEARL
800 horsepower GTR
450hp@4wheels@1bar optimax
520hp@[email protected] optimax
The car is tuned to 2bar of boost.
Redline 9000RPM
Twinn KKK K26 Blitz Top Mount Turbos
Blitz Manifold
Twinn External Wastegates
Hks 280 Cam Shafts
Hks Cam Gears
Modified Headwork
Balanced Crank
Short Pin Rods
ARP Rod Bolts
Nismo Oil Pump
Nismo Water Pump
All custom piping
Motec Ecu
Custom Fuel Rail
720cc Injectors
Sard Fuel Regulator
Hks EVCiv
Tein Coilovers
Recaro Drivers Seat
Endless pads
Air Conditioning
Full Alarm Sysytem
Sony Cd
OFEERS OVER $85000
Family Situation Forces Sale
Genuine Ineterests Only Please. ph 0404134400
these turbos were on my built 2.7 previously and made 652hp@the wheels at 1.5 bar, with 103 octane fuel.
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
