Hi guys.
Wondering if anyone knows why my power steering fluid is spewing out of the reservoir once the car has stopped. Sometimes whilst driving too. Power steering works fine so no blockages. Any suggestions would be great.
They do that if there is air in the system, is it foaming up at all? Any funny noises?
Try slowly going lock to lock a few dozen times on a loose surface, or while jacked up, topping up the res if required, that's how I usually bleed the air out or the rack. If you just bought it they may have changed the rack recently? Otherwise you may need a new pump I guess, or a seal is leaking somewhere.
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
