XTC Drift Day @ Morwell - Invite to SAU
Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
Yes it can be adjusted so that it does not ruin the party in Nistune. But you must have the sensor connected or the ECU will be bitchier than a teenage daughter.
Agreed, wooden ramps can’t go wrong. Or buy low profile ramps ie. gktech
By RB25inside · Posted
UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
