Car is completely stock, has Nismo exhaust and front pipes but standard dumps :(
So that's what... another 10k in mods to get it to 300+rwkw?
Maybe not that bad given I can do the labour myself - not the tuning.
EDIT: Looks like prices have changed a bit and it's not that expensive to get 300-330 on 98.
-7 or -5s
Injectors, Fuel pump, Cam gears
Cams not necessary but would help (and sound lovely)
PFC and tune
Full exhaust, some conjecture on 3 or 4"
AFMs
Standard intercooler and airbox fine.
Edited by ActionDan
Speaking to the salesman, not good.
"With the vehicle itself the price is fixed we are not discounting the vehicle so it’s probably not the vehicle for you in that case.
To buy this vehicle at today’s exchange rate it would be even more expensive."
Irreplaceable for that money."
I'm trying to get parts thrown in, anything.
I've just sent one final email to say is there absolutely no room for negotiation in this?
As much as I love the car, when you seen fairly nice examples around for 55k (white) with a built motor, 59k more or less for a stocker (even a nice VS2) seems a bit expensive for my budget.
Edited by ActionDan
This SAUWA R34 for $55K ~ was always my Benchmark for pricing, to date i still think it was the best value R34 to sell in recent years
http://www.sau.com.au/forums/topic/446039-r34-gtr-v-spec-5a-import/
Other solid buys to memory are (forgive me if the values are off, these are listed prices;
Matt's KING87's GTR $55k ~ with genuine Z-Tune guards/bonnet, 6-pot Brembos, Mines piping - http://www.sau.com.au/forums/topic/146573-r34splease/page-149
and Tangomatt's GTR - $90K ~ ~ with Everything, basically a 1/3 price Z-Tune with more - http://www.sau.com.au/forums/topic/287693-racepace-built-r34-gtr-nur-rb28-v-cam/page-1
Another soild one was this Black V-Spec with HKS V-Cam pushing 340awkw for $65K ~ - http://www.sau.com.au/forums/topic/401854-fs-r34-gtr-v-spec-with-hks-v-cam-ex-tpg34r/
Edited by squareznboxez
  • Like 2
The missus was not pleased about the prospect of a 55k car that still needs another 5-7k spent and won't see much track time lol
She was more OK with the idea of 55k finished and I would actually use it a few times a year on track.
With that VS2 I'd be reluctant to go harder than 7/10s I think...
I want it all for 55 lol
Vspec2 all the bolt ons etc.
The reality is that doesn't seem to exist.
The other issue I have is being jaded by the QLD car.
Now having a harder time justifying that kind of coin for a 15yr old car.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
