OK for shits and giggles I enquired about this...
http://www.carsales.com.au/private/details/_/SSE-AD-3540905
Started talking to the guy on FB. Seems really friendly and helpful.
Assuming it would be a shitbox I started grilling him about how it's obviously been crashed etc.
He's tells me not in the time he's had the car (6yrs) and that he can't see signs of it having been hit... ok weird. "I tried to find the cleanest stock one I could".
Questioned the guards, bonnet, and front bar, boot.
He tells me, the bonnet came on the car, the guards he had made up (fibreglass but apparently really good quality, google tells me the nismo z tune guards are even fibre glass and only the actual z tune had CFRP guards).
The boot he had painted because he likes the look. Front bar and spoiler have been sold as he was not planning on selling the car. A top scret replica front diffuser is there as are the stock mirrors and guards.
He tells me the car also has a PFC (not listed on the ad), tuned for 240kw with stock turbos etc (1.2bar) as that's all he wanted.
Rims are also genuine.
I ask for some more interior photos - see gallery it's easily cleaner than the QLD car and not the existence of v-spec sensors on this apparently non v-spec car (i know you can add those sensors later indivudally and reconfigure the MFD or go the nismo MFD way)
He's getting me a VIN so I can do some digging and confirming K's etc.
He tells me underside is quite clean and nothing like the car i showed him and the only rust on the car is the two radiator tabs and that's why he showed me those.
I'm starting to think this could be a good cheap base to work off, spray the front bar, bonnet, boot, re-add spoiler (A mate of mine is an excellent spray painter with a business etc), get a rear diffuser and fit top secret replica front. -9s, injecotrs, pump, cams/gears and retune.
Am I crazy? OF course I would inspect for signs of crash damage, but if you could get this cheap and the k's and condition checked out...
http://imgur.com/a/FZIjK
Edited by ActionDan
Turbos seem to be about 1500-2k on the gtr group, injectors 500, fuel pump 200 or so and afms 4-500? 3k or so then a bit more if i wanted cams and gears, gears alone are bugger all.
Maybe 4k in parts there, rear diffuser is expensive 1500-1800 so i would just sit on that til i found one cheap.
The paint work would cost me the cost of the paint and some beers.
If you got the car for 40, spent 7 or so, that doesn't seem too bad?
The QLD car was going to be 46k with the spares so it would have come out cheaper but with all that rust to deal with and 55000 more ks (if the ACT car is genuine, wont surprise me if not).
Edited by ActionDan
8-10k if starting from scratch I think?
This has EBC, PFC and "full hks exhaust mines dump pipes" already.
I would be "guessing" to say that if it has dumps and an HKS exhaust it likely has fronts and cats done but fair point as that's extra cost, neither of which are that expensive.
Already has ATS clutch as per the ad,
Cam gears are cheap.
Tune is a valid point, I'm not sure if there's a 4wd dyno here so would likely get Chris at RacePace to tune it, when I spoke to him last he said tunes for adding mods like that aren't too bad, 4hrs etc, so less than 1k. I know some local tuners but the dyno access is the issue, one of the 4wd shops might have one but they get pissy about letting people use them.
I can do all the labour required (not painting but that's mates rates).
Edited by ActionDan
Dan that's a bit of a hidden gem imho.
Many won't have even considered because of the boot/bumper.
I personally would go stock guards, bumpers etc but that's me.
Leaves you a LOT of wiggle room to do things how you want. And you can play with cars again (aka hunt for parts etc)
DO IT
I thought that to switch R34 into RWD mod required bleeding the ATTESA system afterwards as it needs t be depressurized or something?
Didn't think it was as simple as dropping a fuse like the 32.
"I can do all the labour required".
I've fitted turbos before. Is it a shit job? Yes, but I'm capable of it. I've tuned (cheating as its only SAFC and SITC combo and some cam gears), aligned, and done all the upgrades on my track car plus all the service and repair of anything else I've had in the past including replacing a blown headgasket in the track car.
Swapping out a TT setup will be balls, but I'll get there when the time comes.
DO IT
I'm wondering this too. inspection and VIN review will tell me more so not getting my hopes up.
I like the Z tune guards, bonnet and bumper combo - once colour coded. Plus when I run off the track and smash up the front bar I won't cry as much knowing it was FRP.
I have the track car to play with so really I'm not looking to play with something else and don't get enough time as it is, but I'm not willing to drop 60-70 to get a fully done one how I want.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
