Hi everyone. I searched but couldn't find anything similar to my problem.
I am trying to clean years of grim, water marks and light corrosion off my wheels. They are Enkei Winsome 3 piece wheels and have a lot of bolts that I am having trouble cleaning around. I have successfully used some metal polish to clean the dish part of the wheel and using a clay block and paint cleaner on the painted middle section of the wheels, but I am struggling to clean the water marks/corrosion around the bolts.
Has anyone got any tips?
I was thinking about removing 1 bolt at a time and cleaning that spot, replace bolt and repeat.
Is this safe?
Should I get the wheels re-balanced after I do this?
What torque for the bolts?
Am I making this more complicated than it needs to be?
Here a a few pics (I hope this works)
Corrosion/Water Marks around bolts
Wheels before cleaning
Wheel now.
  • Like 2
https://www.sau.com.au/forums/topic/459727-cleaningrestoring-3-piece-wheels/
Before you take the bolts out you can try with a dremel with an extension, polishing head and some metal polish and see how you go. If no good then yes you can take a couple of bolts off at a time. You can always check the torque with a manual torque wrench when you take them off. Then use the dremel to polish it.
Its a prick of a job but well worth it.
Edited by XGTRX
Thanks Guys,
I am going to pull the wheel off the car tonight, sitting hunched over on cold concrete for 3 hours last night killed my back.
I will try with the dremel with the bolts still in first but I think it is going to be harder than removing a bolt or 2 at a time then cleaning/polishing by hand.
I will post up pics when I am done.
Trex - To get them to the stage they are now I have just used Autosol Metal Polish with a tennis ball wrapped in a microfibre cloth, the tennis ball made it easy to do the dish part of the wheel. http://www.supercheapauto.com.au/online-store/products/Autosol-Polish-Metal-350g.aspx?pid=345178#Recommendations
However, my wheel are raw alloy, no clear coat or anything. From the reading I have done online, clear coat on some wheels is really hard to cut and polish but it can be done.
For the painted middle section I have used Meguires Ultimate Compound. It is awesome stuff, cleaned up and and removed really deep scratches in the paint on my Patrol. http://www.supercheapauto.com.au/online-store/products/Meguiar-s-Ultimate-Compound-450mL.aspx?pid=214309#Recommendations
I will check out the polishing BBS RS videos tonight.
Cheers.
  • Like 1
Small update of what I got done tonight.
I tried removing 2 bolts at a time but it wasnt working very well, I let all the air out then took out 4-5 bolts at a time. Screwed around for hours before I worked out a quickish way to do it. Takes about 45nm of torque to undo the bolts so I am tightening them back up to 40nm because I figure it takes a bit extra to crack the bolt. I have decided I will get them rebalanced and checked when I am finished just to be safe.
Cleaned loose crap off with Shellite, then cleaned off the chunky corrosion with a tiny steel brush dremel attachment by hand (not in the dremel) then polished by hand the remaining scuff and marks etc with the metal polish. Cleaned up the head of the bolts with a polishing attachment in the dremel with metal polish.
It is going to take forever (took 5 hours to do about a third of the wheel) but I am really happy with the result.
Before
After
The wheel so far.
  • Like 5
spent about 4 hours on mine today, arm about to fall off
has anyone dealt with deep pitting in the aluminium? i can sand it all out but some it is fairly deep and dont want to take too much material off
I have finished one of the wheels. It looks good but I am not happy with the centre.
I have decided to go all out of the next wheel. I was thinking about getting the centre electrplated (either chrome or a satin finish) but first I am going to try polishing it myself.
I completely dissasembled the wheel this time. Used paint stripper on the centre then polished up a section to see how it would look, I think I am going to be able to get it to a level I am happy with. If I cant I will look at getting the centres painted or electroplated.
Pics...
First wheel finished. (centre is still painted, hosed it down to see how the raw alloy would look after the water dried)
2nd Wheel pulled apart.
Test polishing the centre after stripping paint. (was only a quick sand and polish, should look better when I spend more time on it)
  • Like 1
I did something similar to a old 3 piece OZ Racing wheel set, only difference was they were clear coated which was peeling and really corroded.
I ended up sanding the outers to get the clear coat off, working my way to 1200 grit, with each sand removing the sand marks from the last grit.
Then buffed with a wool buff and cutting compound on a drill, final finish was done with Autosol, they came up mirrored like chrome.
You may be spending too much time on them because you are not sanding through the corrosion.
Those inners with the rough cast are best sanded smooth first to remove the rough casting, then polished.
  • Like 2
  • 1 month later...
I finally finished the first wheel today. I am really happy with how it looks but I am going to look at getting someone else to do the rest of them. Wasn't too hard just took a huge amount of time.
Still missing a few bolts that snapped when I took them out.
  • Like 3
  • 2 months later...
Last update.
Finally got around to replacing a couple of bolts that snapped when I pulled apart the wheel, fitted, balanced, etc.
Really happy with how this one has turned out, but I am going to get the test polished professionally. Not worth the time or effort to do it myself. I reckon I spent 40hours on this wheel.
  • Like 3
I was thinking about some sort of protection for them. I would prefer to avoid clear coat and have found references to "wheel wax" that protect raw alloy wheels. I think I will give that a try forst. The car also only does <1000kms a year, always garaged, etc so I am hoping this wheel wax stuff will suit.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
