Does anyone know if the jdm 370gt has the tyre pressure thing going on?
Had someone who could read Japanese tell me there was an option in the speedo display that said tyre?
But had the tyre off the rim n no sensors unless some retard discarded them somewhere along the line.
Will soon be fitting q60 cluster so I can sus all the shit in there out.
https://www.sau.com.au/forums/topic/459874-tyre-pressure-sensors/
No idea about the TPS. But fyi I think it is a HUGE leap to assume that a Q60 cluster will be a plug and play affair on a V36 - the wiring differences between USDM G35s and JDM V35s were pretty significant in some areas - I would imagine the V36 vs Q60 would be the same level of differences.
Got a guy in Europe who has checked schematic on both models pretty much the same,us models yes massive difference as to why he has made up new harness for my English conversion complete swap out of gear with with updated software to 2014,new buttons,new navi unit with Aussie maps,new heater n stereo buttons,gives me Bluetooth streaming n heaps of stuff,works sweet,was a few grand but it's the bomb.
As for cluster all it is is a slave
Was just going to use the lcd from it but I like the look of the q60 cluster
The only f**k around is the eprom chip that needs to be removed and re soldered into the q60 cluster to keep mileage.
Wow, nice work there Justin - looks like you have really done your homework! Also looks like when I buy a V36 in the near future I need to take it to you and get a conversion package done on it :)
Oh man I tell u the amount of emails and conversing that's been done is ridiculous.
I'd spoke to a few people in Aus about n I got such a mixed bunch of theory's and opinions.
Some people wer installing the Aus map n using stickers on the jap buttons,personally I think that is chat looks unprofessional n a bit tacky.
Some said I couldn't do it with any v36 under 2010 some said it was a 10k exercise etc
And I read all the convos on here n was pretty confused about the whole thing.
But like this guy said we arnt driving nasa ships lol
U just need to know what your doing and have the right resources.
Although it's not cheap at all I think it's worth it,considering how beautiful these cars are and for resale also people can enjoy the full potential of the car.
The English kit was $3080 and q60 cluster from Infiniti in Melbourne is $1100.
Thanks talkiet.
Makes sense now as I read about the service thing u can set.
I'm waiting on some more info but I'm hoping to adapt it to mine as the 2014 q60 set up has it I'm pretty sure,it's just a matter of if the in dash unit has the frequency pick up inbuilt or if it's an external stand alone unit integrated with the system
Yeah no worries
There has been a few hic ups like the wheel camera but we found that the fx37 have a wheel camera so we are using that button cluster as it has the camera button in the same place and actually sez camera and fx37 unit and stereo climate button panel
As for the TPMS I just received info that it is a seperate unit that is easy to get and easy to instal although it needs to be programed into the bcm which I think might be a bit of a task.
I'm waiting on a definite if it is possible to be programed into it,if it's a yes I have a tech at Brookvale Nissan who's Ment to be the best in the country who wins the annual "tech off" every year sonic been told.
I'm yet to speak with him about the mileage correction as u can also re program that so the q60 cluster mimics the mileage of the jdm cluster,in a sense it seems easier than getting a temp controlled soldering iron and swapping out the eprom chips.
I mean that's if he is clued on programming a cluster,there is also blokes out there who run instrumentation company's for this type of work which I'll look at if the Nissan guy isn't confident.
Ok so yes it can be programed into the bcm once sensors are in and installed and control modual is in same as speedo can have mileage done using consult 3
Was just at Nissan Due to legal reasons they can't do cluster mileage unless it's a warentee job and dont really want to set up the TPMS they said it could be done but it would just take them ages which will cost heaps.
So bin that idea
My guy uses consult 3 also but really knows how to use it.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
