Ive been thinking about upgrading the headlights and weighing up the pros and cons of a few options. So I wanted to gather some opinions on what successes people have had.
Option 1: staying halogen. (safest and legal)
What are the best globes out there for best light output? I think I have some of the narva +whatever ones in there. Put them in years ago.
Would there be any benefit in creating a new relay circuit so the headlights receive full battery voltage? (there may be a voltage drop through the existing wiring with more powerful lights - have not tested yet)
Option 2: HID conversion (fairly simple and inexpensive, not legal, more obviously defectable, more glare)
How is the light pattern with the stagea reflector housings? I would like more light, but don't want to be a flamin mongrel to other drivers. There is obviously a quality difference between kits, with differing bulb shields to reduce glare.
Option 3: high beam only upgrades. (custom fabrication, no guarantee of effective outcome)
Has anyone done anything useful with the inner foglights on the S1 headlights? For starters the, the headlight will have to be dismantled in order to remove the yellow filter. While there is a central cone of light coming out of them, there is a lot of light dispersion. However these would never be on when facing oncoming traffic, perhaps they could function as extra driving lights?
https://www.sau.com.au/forums/topic/460537-s1-headlight-upgrades/
If the objective is better night vision then light bars won't do anything for you. I assume that headlamps are already supplied via a relay so that just leaves getting the best possible bulbs for your headlights and/or replacing the foglamps with driving lights.
  • Like 1
Are you looking for high beam only? I recently went LED high beams in the Leaf, not sure what globe type the stag takes but you may be able to use the same or similar
http://www.banggood.com/H8-H9-H11-20W-Cree-XML-2-LED-SMD-Car-Fog-Headlight-Light-Bulb-Xenon-White-p-976889.html
  • Like 1
I was just getting to option 4b - LED replacements for globes..... Just to clarify are you suggesting retrofitting H4 LEDs? Or putting LEDs in the foglight spot?
I was under the assumption that while LED headlights are going to be the easiest way to go, the light output is still similar to a halogen. Im sure high end ones are great.
i always found my headlights to be fine. what exactly are the problems you're having?
i am using phillips white vision which are 4300k.
The high beams are OK (could always be better) but the low beams are a bit dim. I get a bit edgy in canberra when I have poor illumination of the roadside, too many kangaroo accidents around.
im in the act too. you're more than welcome to check mine out before you spend money on something that may not need changing ;)
and with the foglight spot. i've seen a lot of guys use the standard h3c globes but with the orange lens in the headlight taken out.
Id certainly love to check out your stagea sometime. In terms of lights though, I have found something. Maybe a doh moment. The bulbs I have in there at the moment are blue tinted osram ones. They are only 60/55w though.
There are now up to 130/100w bulbs available.
However, is it safe to run higher wattage without melting the housing?
Should I run a new relay with some heavy wiring to the battery?
  • 1 month later...
sorry to bump this bk to the top.
ive fitted 35w H4 hid's and 24" led light bar this has made a very big diffrance in night time driving
I read enough about dual hi/lo beam h4 HID conversions to put me off the idea. How is the light pattern, glare, beam focus, etc?
I ended up sticking with halogens, though I made my own heavy duty wiring harness and Im using slightly higher wattage bulbs. Nothing crazy like 100+ watts though (which would probably ruin the housings). Results have been good - the low beam is much brighter, but has a very distinct cutoff
Light pattern with hid is better than using halogens. beam focus is very good and glare is a bit of a pain but all Ive done is turn the light units down a bit.
Hi beam is good get very good light coverage and you can pick up thing a lot better in the distance. Hi beam is even better with the 24" cree led light bar.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
