Hey Guys, I'm sure it's asked all the time but i'll ask again..
I have an S1 C34 RS4 Auto Stagea. Car was completely stock 170xxx K's, Only thing i added was a Pod filter.
I've replaced the spark plugs due to missfire and checked all piping etc to ensure not leaks.
I've been running it on 95 but i can only seem to get 260KM out of a full tank.. Usually a mixture or shorter trips and highway drive.
I'm not too hard on it, usually had OD on on highways etc, give it the odd squirt from the lights every now and then..
Can anyone suggest anything i should check or change to try and increase this? I plan to refit factory airbox and run on 98..
Also ever since i got the car it virtually always seems to be on boost.. If sitting on 50k or 90k even with OD on, slightest feather of throttle and its on boost straight away.. Or holding steady at 100k with OD its sitting on boost... Any ideas? I'm not sure what else to check..
Any advice would be great! Cheers
https://www.sau.com.au/forums/topic/460742-rb25det-consumption/
Yeah correct plugs with 0.8 gap. I've just cleaned out the o2 for now and ill refit tomorrow to see if that helps
I believe it may have a boost leak, Sometimes it never comes on boost at all even with pedal completely to the floor.. It was sitting for 18 months before i had it with little to no maintenance so i'm not sure exactly what to chase
My bro's Stag always seems to be on boost too, one of the very first things I've noticed once we installed a boost gauge. Need to fully back off the throttle for boost to drop
O2 sensor did help but its still thirsty, probably less than 400km per tank. Weight and small capacity engine don't help I spose
You can see if the o2 is working with CONSULT, but if you cant get your hands on one of those just assume its dead, replace it, and reset the ECU so the long term fuel trims are re-established. Change one thing at a time and do the consumption calc over 3 tanks so its a bit more accurate (ie sum the liters and kms from three tanks together then do the calc).
Once you've done three tanks with the new o2, try 98 and recalculate over the next 3 tanks.
Dont forget to check the tyre pressure - 2psi over what the placard says is an ok start.
Dont run too thick an oil. 5w-40 or similar should work well.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
