Hey Guys,
So i bought a 2000 Stagea RSFourS (WC34 ), the last one in Canberra, and am loving it!
But with all cars, age has run it's course on a few bits of the car and some stuff needs fixing.
so i was looking for a bit of advice, any you guys can give would be greatly appreciated.
the major issue is the suspension, its cactus, the fronts are leaking and need replacing, and i was thinking of getting coil overs.
the research i have done suggests i have fork type suspension so i was thinking of getting these http://justjap.com/b...-type-3116.html
Has anyone used these before, or have advice on a better choice?
One of the other issues i have is that the drivers side mirror (mirrors are electric) at speeds above 90 or in high winds it begins to move and unset itself.
It appears to be the actual bodywork bit of the mirror, not the actual reflective mirror bit, as trying to move it with the electronic controller doesn't work.
​Which means i have to wind down the window and move it manually with my hand, has anyone had this sort of issue before? or know why it is happening or how to fix it?
Thanks guys, if anyone has any other tips or knows mechanics in Canberra they recommend, id really appreciate it.
(I attached some pics for those interested)
It could be the motors in the mirrors f**king up my mirrors don't close from high winds like yours but they don't open if I retract them I know you can get heaps of mirrors from wreckers but who knows the condition of the motors aswell. My suspension was shot to when I bought mine and I found a set of tein superwagon coilovers there awesome don't go low but good coilovers
Japanese Import Spares in SA have new motors for the mirrors. I'd be sitting down though when you look at the price.
The S2 mirror motors can be replaced, the S1 mirror motors can't. Both will fit on an RS Four S though.
Hey all, so an update.
I took it to AutoTech in Hume to get it looked over, some minor leaks (coolant and gearbox), front bushes and a bit of rust beginning to appear in the top of the strut towers.
However that's not the bad news, the bad news is that cyl4 has a compression issue, that they told me will eventually kill the engine, unless it is rebuilt.
I got rough quoted 7k for a rebuild, which was a bit of a shock, esp given its an 11k car.
I spoke to a mechanic friend of mine and some others and they suggested swapping in the RB26 engine, instead of getting this one fixed.
So i was wondering how hard that will be to do? im guessing it will be relatively easy as the Stageas came with them in some models (Autech), but appear to have little else changed (5 speed gear box still etc)
I was thinking that id also like to swap the front bar for the R34 GTR front, similar to this:
So i was thinking about getting a Half/Front cut, since then i get the front bar, side fenders, bonnet (though i have been told the stagea one should fit) as well as the cluster and wiring harness.
I have been struggling to find a place selling one in aus though, anyone know a place selling one, or could find one?
Has anyone got any experience with this engine swap, and do you guys reckon it will be worth it?
Thanks
Hii, There are plenty of good second hand Stagea RB25DET Neo Series 2 Engines about, If you wanted to put an R34 GTR Engine unit complete with all the engine wiring, ecu, pipes, hoses ect, Wow there is one on Ebay now in auction 2 days ago it was up to $19000us+, Mind Blowing, I couldnt believe the price, But Your Neo if it a manual engine puts out 220 kw out of the Factory, more grunt than the R32 gtr,206kw A good 25det neo will be your best bet $2500 to $4000, But make sure it has been compression test and garanteed before you buy one, I run Tein road & track adjustable damper, Hieght Adjustable Coil Over, Paid $800 for then second hand of a gtr 5 years ago now & they are still working fine. Hope this helps Jamind
MCA Blues are only $200 more than the BC's. MCA's are proven adjustable coilovers from the same company who has been on the wtac podium 3 years in a row, took out fastest rwd and 2nd fastest outright in pro class. Australian made, with Australian warranty, with a company who has a face.
How bad is the compression on cyl4? Get a second oppinion. Go see the blokes at techworkz or import parts canberra as they both know their stuff.
Beware that the front cut may not come with the bumper, lights etc that you want. if it does, it will cost you a hell of a lot more than 10 grand.
A bloke just sold his s2 with a 26 engine, if memory serves it was ~9 grand. So look at the cost vs resale.
You can buy a genuine 250/260rs for 15-20 grand and sell your s2.
Thanks
What exactly is the compression issue? i.e. what are the compressions ?
Over here a good Neo engine is $2k so don't go rushing into a rebuild..
If you want an expensive hobby go ahead and spend $40k on your car. If you want a fast well handling Stagea take your time and buy one already done for way less than half that and sell your present car and be ahead $$$$
The compression are:
1 155
2 155
3 155
4 120
5 155
6 160
The reason i mention is a new engine is that if im replacing it anyway, why not put something better in?
I intend to keep this car for a while, so im not really keen to try my luck buying another car.
I thought you were someone else when i first saw the picture.
Do you drive around condor much? I was in the silver stagea.
I live in theodore so you might see me driving around south side a fair bit,
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
