Hey guys
Sold my car and have some parts that never got a chance of using and some OEM used ones, basically a garage clean out will keep adding as i find more stuff.
1) Brand New in unopened box CST Type Vettel V36 coilovers fully adjustable with 14k front and 9k rear spring rates and 16 way damper. These are made in Japan and distributed by Tanabe. $1500 ono (pic of suspension out of box from google, i havent opened my box yet)
2) Blitz Power-sus intake panel filters also BNIB $120
3) V36 Type S and SP front lip kit ( Fibreglass sides with CF middle part, see pics) $550 ONO
4) RS-S LowDown springs BNIB $400
5) OEM Used Exhaust axle back Muffler and y-pipe $100
6) OEM Used Manifold $100 (good for anyone needing to send one into z1motorsports as core unit)
7) OEM Used rear chrome bootlip $50
8) OEM Used 18" V36 Coupe wheels made by enkei in excellent condition need tires $500
9) OEM Used 18" V36 Sedan Type SP wheels also in excellent condition (front tires good, rears need replacing) $500
10) BNIB plug and play V36 cruise control kit (comes with a little wheel knob that can be used to set/cancel and increase/decrease speed see pics) $500 ONO
Thats all from the top of my head, like i said if i find more stuff ill keep adding.
Offers only accepted if i have put an ONO next to the price or else its non-negotiable.
PM will be the best way for enquiries and everything located Southwest of Brisbane
https://www.sau.com.au/forums/topic/461196-v36-parts-for-sale-garage-cleanout/
  • Replies 60
Posted Images
It works both as a cruise and throttle controller, install is simple plug and play as it is V36 specific and will fit into factory accelerator harness and a few wires need to be hard wires like power and brake pedal. Check the attached wiring diagram.
VQ35HR and VQ37VHR Carbonfibre intakes used for about 1000-1500kms only.
$350
Was there a reason you removed it after a short time ? Did you notice any performance increase or atlest better exhaust note while it was in the car ?
Thanks mate
Thanks mate
Removed as i was selling the car and had recently bought them and i wasnt gonna get much back after owning the car 3 yrs so took out a few bits and selling them.
Not sure about performance gains but it has a real good induction sound and exhaust got a tad bit louder too.
  • 1 month later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
