Hey guys, got a question. Where are your stock r32 gtst temp gauges are sitting? Recently bought myself a 92 Skyline r32 gtst and its bothering me that temp sitting a bit above the middle, its sitting stable but not sure if its normal to be there or if my engine is running hotter than should be all the time or if the gauge is faulty.
Any input would be appreciated. Thanks
https://www.sau.com.au/forums/topic/461245-temperature/
Thanks lads, how hard is it to get the aftermarket temp gauge hooked up? Or is it just easier to take to a work shop to get that done? Anyone knows how much gauge install would be roughly if it was done in a shop?
https://www.sau.com.au/forums/topic/461245-temperature/#findComment-7643384
Yerh will check out some Youtube stuffs tonight and see whether I got stuff required to get it done at home. Also, does anyone know whats the go this days with gauges and where they can be on the dash without being f***d by police should you get pulled over?
https://www.sau.com.au/forums/topic/461245-temperature/#findComment-7643396
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
