Car came with the HKS oil cooler kit, which includes a thermostatically controlled sandwich plate on the block.
I've just done an oil change and it sucks and is messy so I'd like to add a relocator.
What's the easiest way for me to do this and retain the thermostat control to the cooler core?
I thought about buying a basic relocator and attaching the the block side on top of the existing sandwich plate, any issues with that?
Something like this - http://www.rhdjapan.com/trust-greddy-grex-oil-filter-relocation-kit-nissan.html
Edited by ActionDan
Still going to be messy, even if you relocate it.
you need missing pieces from this kit
http://www.rhdjapan.com/trust-greddy-oil-cooler-filter-relocation-kit-r32-r33-r34-y33.html
Look at the illustration image to get an idea of what you will need to achieve. Top image shows what you need to do with a sandwich plate, bottom image is without and a inline thermostat instead.
I say just leave it. Surely its not that much of an issue to just degrease in there? unless you will be replacing the filter every month.
You're directly connected to this forum aren't you... it's all just lines of code in your brain... you're everywhere.
Anyway, I know what I need from that kit, but as that would be next to impossible to get (as bits) I considered just getting a generic relocator and bolting on top of sandwich plate.
And to be fair, probably only need one oil change a year, time based rather than Ks, but the mess 0_0
stacking them is completely fine.. I am going to do the same thing (one day) when I am bothered..
below pic is great, shows it fits without hitting naything
  • Like 1
I'm not back near the car until the weekend, I'll get some pics then.
I've got a relocator on the block, a separate earls thermostat (with pressure and temp senders) and a large cooler where the AC condenser was.
812ta3bDrvL._SL256_.jpg.
Even in a race/rally car it ran too cool at times for me, particularly when driving to events or between stages. And the setup help temps well even on 30klm stages at 40o at Targa High Country last year.
I previously had the filter upside down in front of the sump and the cooler in the PS wheel well but there isn't a lot of room there for a large cooler and I wanted the thermostat, so I redesigned.
I also have a hks cooler kit and i used a greddy relocation, replaced the barb fittings that come with greddy kit and got fittings to allow the hks lines to be used as well
the oil filter is on a simple bracket of right angle 3mm steel (because I hate filter mounts that twist when you try and remove them). countersunk stainless bolts into the filter mount on one side and into 3 thread inserts on the car side. Nice and solid.
the stagea mount is just to give a little clearance between oil lines and the engine, I think most people just do it rb30 style and bolt the relocator straight to the block which also works fine.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
