Hey guys having trouble with my R33 series 1 skyline. Since replacing all heater hoses and fuel hoses in the engine bay the bloody thing wont run .
Since it has been down i have changed the cat to a 100cell 5" body with 3" flanges , fitted a new optima battery and It had a safc which i removed, i did reset the ecu while battery was out.
I have tested the following:
Cas and injectors
Has a brand new walbro fuel pump hard wired with a relay
New Coil packs and spark plugs gapped at 1.1mm and tested spark.
It will run and idle but puffs a bit of black smoke with Afm and ecu coolant temp sensor disconnected, it will run for approx 3-5min before cutting off.
Replaced the Ecu coolant temp sensor and will kick and start with Afm connected but will die after 15 seconds or so.
Boost leak checked.
When slowly accelerating it seems to miss and splutter and if continued will shut off even with Afm connected and wont even make boost.
Has not been comp tested yet.
Anything else to look before i tow it to the mechanics.
Located in Port Macquarie.
https://www.sau.com.au/forums/topic/461823-rb25det-kicks-but-wont-run/
So you went back to stock by removing the SAFC.
Did you reconnect everything back to stock after removing it?
So whats left thats modded and not original in the car that is connected to fueling and reading air flow?
Sounds like its running pig rich....
Is it possible that you have mixed up the fuel hoses?
Thought this, not the case though it idles for 3/5mins in limp mode without afm and ecu temp sensor before i think the ecu shuts the car down.
Yeah went back to stock and just followed the tutorial on install just in reverse, i have had the car running without it previously before changing the hoses etc.
The fuel pump is modded walbro 255, afm is factory have a z32 but didnt really want to splice in as i have a adaptronic with map that will be going in soon.
Im thinking timing and possibly ecu?
Why was there a SAFC - do you have upgraded parts? Correct coils (not S2 coils)? Can you swap out the AFM with a known good one? Plug ok? Changed engine bay fuel filter?
Safc was installed when i purchased the car . Coil packs are S1 have two sets bought a 2nd to test with. Other then a front mount thats the only upgraded parts other then those mentioned above. Stock turbo & injectors , Did have a bleed valve running 10 psi with the safc and have put a greddy boost controller on it and tested with both while the engine was running no issue previously making boost.
Changed the fuel filter when the hoses were done.
Edited by Pauly The R33
Is the fuel pump running, can you hear it prime when you turn the key? Does it sound right/ Sounds like a fuel starvation thing, fuel filter, regulator, pump thing to me??
Check you have fuel getting to the motor.
Fuel pump primes . heaps of pressure actual reason i replaced the hose is because the were starting to leak due to the new pump .
Fuel filter is replaced , have not tested reg but shouldn't the car not run with ecu sensor and afm disconnected.
Afm for ecu air flow & ecu coolant sensor for fuel injection lead me to think it was ecu after getting a new sensor. Put the esel15 in and was doing the same thing and it runs a map instead of afm to rule the afm out.
If you hook it up the wrong way it will still get fuel but not enough. Not having a go but plenty of people have hooked the lines up the wrong way.
All good man i know what im looking at but thanks anyway. Also the fuel filter does have an arrow pointing out which way it flows aswell.
It's more about putting fuel in wrong end of the rail that gets people.
Ok sweet lets establish that the fuel system is correct and we have fuel to the cyclinders with spark. It will run without the Afm And ecu coolant sensor but not with them. Anyone had any experience with an issue such as this?
If it runs without the coolant sensor then you need a new one. If you unplug the coolant sensor the ecu provides a start-up map to get you going.
But as above try plugging the safc back in and see what happens.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
