Hey guys having trouble with my R33 series 1 skyline. Since replacing all heater hoses and fuel hoses in the engine bay the bloody thing wont run .
Since it has been down i have changed the cat to a 100cell 5" body with 3" flanges , fitted a new optima battery and It had a safc which i removed, i did reset the ecu while battery was out.
I have tested the following:
Cas and injectors
Has a brand new walbro fuel pump hard wired with a relay
New Coil packs and spark plugs gapped at 1.1mm and tested spark.
It will run and idle but puffs a bit of black smoke with Afm and ecu coolant temp sensor disconnected, it will run for approx 3-5min before cutting off.
Replaced the Ecu coolant temp sensor and will kick and start with Afm connected but will die after 15 seconds or so.
Boost leak checked.
When slowly accelerating it seems to miss and splutter and if continued will shut off even with Afm connected and wont even make boost.
Has not been comp tested yet.
Anything else to look before i tow it to the mechanics.
Located in Port Macquarie.
https://www.sau.com.au/forums/topic/461823-rb25det-kicks-but-wont-run/
So you went back to stock by removing the SAFC.
Did you reconnect everything back to stock after removing it?
So whats left thats modded and not original in the car that is connected to fueling and reading air flow?
Sounds like its running pig rich....
Is it possible that you have mixed up the fuel hoses?
Thought this, not the case though it idles for 3/5mins in limp mode without afm and ecu temp sensor before i think the ecu shuts the car down.
Yeah went back to stock and just followed the tutorial on install just in reverse, i have had the car running without it previously before changing the hoses etc.
The fuel pump is modded walbro 255, afm is factory have a z32 but didnt really want to splice in as i have a adaptronic with map that will be going in soon.
Im thinking timing and possibly ecu?
Why was there a SAFC - do you have upgraded parts? Correct coils (not S2 coils)? Can you swap out the AFM with a known good one? Plug ok? Changed engine bay fuel filter?
Safc was installed when i purchased the car . Coil packs are S1 have two sets bought a 2nd to test with. Other then a front mount thats the only upgraded parts other then those mentioned above. Stock turbo & injectors , Did have a bleed valve running 10 psi with the safc and have put a greddy boost controller on it and tested with both while the engine was running no issue previously making boost.
Changed the fuel filter when the hoses were done.
Edited by Pauly The R33
Is the fuel pump running, can you hear it prime when you turn the key? Does it sound right/ Sounds like a fuel starvation thing, fuel filter, regulator, pump thing to me??
Check you have fuel getting to the motor.
Fuel pump primes . heaps of pressure actual reason i replaced the hose is because the were starting to leak due to the new pump .
Fuel filter is replaced , have not tested reg but shouldn't the car not run with ecu sensor and afm disconnected.
Afm for ecu air flow & ecu coolant sensor for fuel injection lead me to think it was ecu after getting a new sensor. Put the esel15 in and was doing the same thing and it runs a map instead of afm to rule the afm out.
If you hook it up the wrong way it will still get fuel but not enough. Not having a go but plenty of people have hooked the lines up the wrong way.
All good man i know what im looking at but thanks anyway. Also the fuel filter does have an arrow pointing out which way it flows aswell.
It's more about putting fuel in wrong end of the rail that gets people.
Ok sweet lets establish that the fuel system is correct and we have fuel to the cyclinders with spark. It will run without the Afm And ecu coolant sensor but not with them. Anyone had any experience with an issue such as this?
If it runs without the coolant sensor then you need a new one. If you unplug the coolant sensor the ecu provides a start-up map to get you going.
But as above try plugging the safc back in and see what happens.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
