Ahh I see what your talking about. The common way to get AUX sound into the M35 stock isn't to remove that cord, but to leave it in place a run an aux cord off the TV tuner in the rear LH boot trim. It sends a signal tho the screen and the screen in turn pushes the Audio out the head unit via that wire I believe.
Doing it this way you can also display video (NTSC in potato resolutions only though).
Or just upgrade the head unit, it's usually more cost effective.
  • 1 month later...
I would also run a new 12v wire to the clarion receivers in the boot roof to allow for a steady voltage feed and improved reception.
For my 1000th dumb noob question, what are the receivers you speak off? Receivers for TV or radio?
They are in the top rear passenger side of the rear roof lining. If you remove the rear roof panels you will see them (2). They amplify the signal from the glass
  • 3 months later...
Well just fitted a new Sony Head unit.
Took my time , used the Iso harnesses.
All went well, tested for sound before refitting everything.
Not much room behind the head unit for cables, especially with added iso plugs and leads.
Tucked in all in gently, put it ALL back together, now one speaker doesn't work.
Great.
Could be faullty head unit, faulty nissan iso harness, faulty sony harness or a break in one wire some where.
:angry:
Great.
:angry:
If you tested it and everything work before you push the HU back in then maybe a wire got crunch/fell out soft of thing? Which ISO did you use?
  • 5 months later...
On 6/15/2016 at 0:30 PM, West said:
I"m the Aerpro man here, if you suspect the iso harness screw up, give me the part # and i can check for you.
Sorry to bother you. Can you advise me of the correct Aerpro part number for adapter cable to suit the Bose stereo model please? My plan is to simply feed an MP3 player into the system initially, then remove the CD-ROM drive and install a 'proper' car stereo. Mine is a 2001 M35 Stagea, BTW. I don't feel like spending a fortune ($500.00+?) replacing the whole centre section, just so I can fit a double DIN unit.
Sorry but i'm not 100% clear on what you're after.
You after ISO harness or T-harness?
If you want something like an RCA in so you can feed your MP3 player into the Unit, first of all, your unit needs to have an AUX button, then you can start from there.
I don't have a Bose HU in my stagea so i don't really know what they look like and what the rear plug looks like either.
Since I have not pulled the stereo out yet, I don't know what I require. Sorry to be so vague. I am comfortable with electronics, so I can make pretty much anything work with anything, but I figured the Aerpro cable might make my life easier. See, I plan to do the whole job in a day (or two), so I wanted to have any adapters to hand before I start. I really don't want to strip the dash out, work out what is needed, reassemble, order the parts, then strip it all down again. Make sense? There is no AUX input on my Stagea stereo, though I was told it is a Bose system.  I have enclosed a photo of my Stagea stereo and the DVD ROM can be seen to the left of the photo. My plans are as follows (subject to change and not necessarily in this order):
* Rip out the stereo and the DVD-ROM drive.
* Install a cheap radio/CD/MP3 player where the DVD-ROM drive is.
* Locate the line level section of the cassette deck, break the line and terminate in a 3.5mm socket, so an i-phone/MP3 player can be plugged in.
* Integrate the radio/CD/MP3 player into the system.
* Install a new SATNAV/reversing camera somewhere.
BTW: I know what an ISO harness is, but not a "T-harness'.
Thanks for your advice and assistance. I am pretty new to Stagea ownership (2 weeks).
Edited by Zaphod
Brain fart
I see
Sounds like you just need a Nissan Bose to ISO, ISO to your HU brand, any Autobarn or SCA can help, i believe the boys here said nissan patrol iso harness will suit.
Not sure if Bose is any difference, you have built in Sub & Amp, if so then you might also need a low or high level converter.
I'm new to the Stagea myself, yet to pull the HU out to check as i'm going to set up GPS/Reverse cam but i'm lucky enough the car already comes with a Double Din Slot.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
