Hmm...
I've same issue with my R, I got 4wd light on as well.
Does your brakes make grumbling noise when you depress the brake pedals?
I've done some reading on/off for a couple of months, one possibility is the relay in abs unit that is fubar, haven't cracked mine open until I've sourced a replacement cos knowing myself, I'll break it.
Hmm...
Well thats the thing no definitive answer as to where the said abs relay is is it attached to the abs manifold ? or next to it and no grumbling just stuck in rear wheel drive and absolutely no sign of abs under heavy braking just slides can you take a picture ? or i can of my bay and see what you guys think ?
Just to be sure you have topped up your brake master cylinder and attessa reservoir?
both topped up to the centre marks on a side note the clutch was recently changed could poor bleeding cause this issue ?
Yep, the relay is inside black box next to the manifold, it's pain in the rear to undo the screws and take the top bit out.
I'm the same, searched for a while with no definitive results.
i have stripped mine down waiting for the replacements to drive now if this is the issue total cost to fix £6.10 still find it odd with no flashing codes on the module apparently if the relay is fubar it flashes pump failure or something along those lines :glare:
Right chaps just got back in replaced my relays with new ones not as hard as people say but to no avail still got the light on and still no flash from the brain when i turn the ignition should the relays click or prime the motor ?
I did notice one of them are looking bit rough but mine happens when it's cold or when I've driven on speed humps bit quickly or into uneven road surfaces.
have you got a standard ECU? I'd put a consult on it to get the error.
no its a mines ecu although i can't even find the socket even if i could would it read th abs or is it just engine side of things ?
hmm i will attempt a continuity test ? where are the plug ends for the wheel speed sensors ?
good news then, mines is just a standard ECU with a tune. the ABS might actually use separate pins to the engine data anyway.
ahh right that is good well am i correct in thinking that the com port for diagnostics is under the dash facing down just by the inner fusebox ? in that case mine is not there i will have a further look tonight
On the wheel well, follow the lines from sensors to the rubber grommet where it'll go into the engine bay.
I was told that it plugs there to the loom of some sort, haven't looked in detail.
okey thank you i will look tonight :glare:
sorry yes forgot to add that bit, it is a grey or white plug near the fuse box.
eg{}:c[e]=d};var l=function(b){xpost-13070-1205647516.jpg.pagespeed.ic.&&0){for(var>
hmm interesting from memory my plug is not there also the fuse panel looks different hmm is yours an s2 ?
Edited by centoproject
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
