98 is too hot for the street (not dangerous to the engine hot, that'd be 110c+ water and oil temps)
Are you boosting around to get the temps that high? Or just normal off boost driving? If its getting that hot off boost, then your cooling system isn't able to keep up, it should sit a few degrees above your thermostat's opening temperature (High 70's / Low 80's) can someone remind me what this is for an RB26?) if the cooling system is up to scratch.
If you're concerned about it, grab a Koyorad to replace the OEM radiator (if thats what you're running) and make sure that your water pump is doing its job properly.
But first step is, make sure your system is holding pressure... sometimes the radiator caps go bad and push out a lot of coolant into the overflow
Normal off boost driving.
It looks like I got a cheap ebay aluminium radiator installed by the previous owner (I assume its still better than oem?). I don't think its holding pressure as it is pushing coolant to the overflow bottle.
Do I just need to replace the cap? Any super cheap auto radiator cap? Or do I need one of those high performance ones?
Give the upper radiator hose a squeeze when the car is fully up to temp (the hose will be HOT, use a rag) but it should be quite firm to the squeeze. If it's not (you can easily squeeze it in more than say 5mm with your fingertips) then look at grabbing a replacement cap as it could be a $15 fix.
A standard one should be fine.
  • Like 2
Rb26 TO4z in traffic today with ac on 80c oil and water temp didn't move off half. But fark the air temp must have been up there as the timing was retarded and thing was idling like a bridge ported rotor.
Oh and never on boost as its laggy as a 3 legged tortoise.
So definitely look at the cooling mate.
Defiantly check the cap, most of the cheap china radiators are far worse than stock.
Saying that those water temps are not off the scale.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
