I noticed there are Nismo instrument clusters for the earlier V35's, which show the speedo going up to 280km/h, as opposed to only 180km/h. (They also have the Nismo logo which looks awesome) However they apparently require the Sat/Nav package, which unfortunately the V35 I'm importing doesn't have. Does anyone know if it's absolutely essential to have the Sat/Nav package, or if there is another option for an aftermarket instrument cluster showing the speedo going above 180km/h? If not, I don't suppose it's possible to take out the Sat/Nav components from another V35, say one that is being scrapped for parts (Already seen two on gumtree which both have the Sat/Nav package) and get it working, has anyone ever tried this?
I'm not planning on taking it anywhere near 180 km/h on the street, but in the future it would be cool to have the option of tracking it once or twice for fun, so it would be useful to have the option of seeing speeds above 180km/h. Plus, having the Sat/Nav package just makes the car feel more "complete", even though it's not useful in Australia. (I understand the speed is also electronically limited to 180km/h but can be removed, would this be defectable?)
Sorry if these question has been answered elsewhere, couldn't find anything with the search function however. Thanks for any information!
P.S. My V35 has a manual transmission
Edited by Arycama
Haven't heard of any swap, try getting the model of the 280kph one and buy for ebay. If you can work a multimeter you might be able to hook it up but i think it uses a different loom to the 180kph. and don't worry about the speed, its not limited, and if you run turbos or superchargers it will go above 180kph
There are two models as the navigation model uses the dash for CAN data, to display the leaf etc. I think either should work in the non nav model, but don't quote me.
What? Where did you come from with that nonsense?
Are you referring to me saying that the Nismo cluster only working with the Sat/Nav version? It says so here:
https://www.japanparts.com/parts/detail/1197
"**ONLY for MY2004/11 and before with genuine TV/DVD Navi equipped model."
As for the "limited to 180 km/h" part, I can't recall off the top of my head, but read that Japanese street cars are electronically limited to 180 km/h.
If either of the above are incorrect, let me know. Or were you referring to something else when you said "where did you come from with that nonsense"?
What does CAN data stand for?
Controller Area Network. It is a fairly standard data bus used in most modern cars so each electronic component can communicate with each other. Some manufacturers use unique protocols, for some components, thus the vanilla type OBD2 readers won't talk to those components.
And as above.. the 'nonsense' statement was likely directed at the idea that these cars aren't limited to 180.. and the suggestion that the Nismo cluster uses a different connector.
The Series 2/3 cluster uses a different connector to the Series 1, but as long as you get the nismo cluster for the correct series, the connectors should be the same.
All JDM cars are limited to 180km/h by law in Japan. you will need an ECU reflash, or aftermarket ECU to remove this.
Not something else - someone else ... pretty much everything that Taine said. Takes a bit more than a multimeter and continuity testing to be sure you get it right. All Japanese vehicles are speed limited to 180km/h and as for having to use forced induction to see beyond 180km/h, well... (nah, I won't go there)
And CAN stands for Controller Area Network, used by a variety of equipment outside of the automotive realm as well, but it's all about carrying control data around in motor vehicles predominantly as a means of minimising the wiring required since every device transmits and listens on the same wires, waiting for its turn in accordance with the ID transmitted at the head of each data packet before it responds accordingly.
All good, thanks for the replies so far. How do I tell what series my V35 is? It's a 2003 350GT coupe. As far as I can tell, the nismo cluster is only for models before November 2004, after that the instrument panel was refined.
^^ this.. clusters are quite different. S1 has speedo and fuel gauge on the left, tacho and temp gauge on the right. S2/3 are the other way around.
I don't know if they actually made a nismo cluster for the S2/3?? someone might be able to correct me there.
    • Looking to do a turbo conversion on my RB25DE Neo Does RB25DE Neo lower intake work with RB25DET Neo Upper intake manifold?    I found an upper only intake manifold for sale but not sure if it will fit the bottom  half stock intake manifold I have already? Thanks  Also if your selling any parts relating to RB25DET Neo pls reply below or dm.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
