Ok the LCD popup screen has a message "pitstop" .
obd check came up with
bank 1, knock sensor.
It only has 1 knock sensor so it cant be the knock sensor, given bank 1 only problem!.
O2 sensors,, I swapped em sides, fault stayed on bank 1, so they should be ok.
The A/F sensors look hard to get at, and possibly need a special spanner?.
Anyone ever removed these A/F sensors, How hard ??
Coil packs, manual test procedure looks to be very hit and miss???.
And injectors need the plenum removed , last resort job there!!.
Anyone have any input, ideas to solve this issue ?
Note.
O2 = middle of cat converter sensor
A/F = above cat converter.
Pitstop doesn't mean anything.
It's just a resettable oil / filter / wheel kilometre counter. Doesn't mean there is an engine code.
Knock sensor I wouldn't worry about it the car is driving fine. Check the wires to it are intact, have been cases of mice eating the wiring in there.
Reset the fault code, and see if any check engine lights come on.
  • Like 1
The pitstop message has been cleared 4 times now & won't go away.
Seems to be more than a maintenance related problem, thanks for the input.
simply putting it out there to see if anyone else had struck a similar issue, & or had some pointers for possible cause and or tell tale signs to look at.
More input the better!.
The ecu is leaning the engine off as a result of knock detected.
Edited by nobby
ECU won't lean the mix if knock is detected.. it retards timing and richens the fuel mix, resulting in poor performance and poor economy.
  • Like 2
Thanks for that, I have been away for a while since the obd unit was connected.
So I can't remember the data , the $3k OBD device my mate owns, he told me it was leaning off.
Perhaps the engine is knocking because there is low fuel pressure, due to a blocked fuel filter? If it detects crazy knock it may throw a code...
I haven't looked at this yet, will soon. thanks.
Well, that's the reason your pitstop message isn't going away. It has nothing to do with the obd port/reader/whatever.
You need to go through the menus and reset the service reminders. I take it you don't have the English conversion??
  • Like 3
spot on!!!
  • Like 1
Ok thanks for that, No I don't have english conversion for lcd screen.
Are you able to walk us through the steps any way??
Soon as I finish typing I going to reset mil manually and see what happens.
Mil is throwing 2 codes.
knock and throttle control relay.
The autel unit only picked up on knock code, but the relay code may be new as it recently had a flat battery, and low power may of caused it, fingers crossed,
And have a look at jap menu see " If" I can work it out anyway lol.
Thanks for the help gents.
There is no throttle control relay. I suspect the Autel is having issues reading Japanese. :P
Sounds like it would be easier to find a mechanic that knows these engines, shame you are too far away for me to help, but I suspect the front wideband O2 sensor is buggered or an injector is blocked.
  • Like 1
Thanks scott, take it the "front" wide band is the top a/f sensor?.
Blocked injector was my first thought but pita to get at, hence putting it out there for another opinion.
Humm no relay, wiring diagram is showing one in section PG page25, but not identical box layout to whats in my car.
wiring dia show 15amp fuse and relay then throttle motor. so this is why I was looking at this.
but to be honest it didn't make much sense about a faulty relay the car drives and not bad at that, and fair mileage about 10/100k.
would of thought if a power relay for throttle was faulty it plain wouldn't of started & or run very badly etc.
Edited by nobby
Ok pit stop has been cleared.
noticed when pitstop message appears -- then I pressed enter nav button, it was cycling between 2 messages top left of screen.
then I noticed in information page a similar messages.
press nav enter again.
a page appears with 4 slide scales on it.
the slides when you press nav enter again can be reset to zero by nav toggle left and enter.
then Itoggled down to next slide scale and continue to reset again.
I reset all 4 scales to zero.
started engine and pit message gone.
Now I am laughing.
But it wouldn't of happened without the input from others, Thankyou
Edited by nobby
F####### now it's gone into limp mode.
And I can't seem to access mil by tapping the go pedal,( in a bit of a bind 1 may say).
guessing go pedal sensor is at fault this time.
lucky! I was about 1k from home when it happened, 1kph max for the trip back.
max revs were about 1200, and then couldn't get up the drive way.
ahhhhhhh
Edited by nobby
You can usually get a little more acceleration if you push the pedal to the floor, but only a little. Turning the ignition off and on can reset the fault, I had to do that while driving down the freeway a few times when using dodgy pedals sensors.
Been in limp mode too many times to remember. :P
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
