It certainly does make 1000BHP but its a AUD auction which doesnt make sense.
check out image http://i18.ebayimg.com/01/i/02/26/38/5e_1.JPG
the car infront parked has UK plates i think, and also why would a person with 0 feedback rating that just signed up to ebay with fake ID just sell a R34 that has 1000BHP ?
just my 2c
https://www.sau.com.au/forums/topic/46296-r34-on-ebay/#findComment-940321
Holy crap Batman!
My new 1999 R34 GTR Vspec turned out to be a series 1 R33 !?!?!?
And someone stole my Racing Hart CP035R wheels gold 17" and put 16" stockers on!!
And just how do you get 1000HP out od a couple of 2835's They are damn good little turbos but that would be stretching the friendship just a wee bit.
https://www.sau.com.au/forums/topic/46296-r34-on-ebay/#findComment-940396
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
