hi just came across a really promising team that have for 1600 nz conversion of your v36......they give you navi/radio usb/ipod/ and ive asked a heap of questions which ill update here
www.autogravity.co.nz/ or for a few pics
hi, yes there is product for skyline, please check http://www.trademe.co.nz/Browse/Listing.aspx?id=1032174679
good luck
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/
Ugh... Looks like they just use the AV inputs to connect an external device. I tried that and the quality was horrible. (Both audio and video) - plus there was no touchscreen - perhaps they also stick an overlay on... If it is this solution though, then their pricing is batsh1t insane.
Cheers - N
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7684522
ok i got a few answers off them it is indeed an entertainment system, but i gather you can switch jap system to this also touchscreen works And bose audio phone/bluetooth they recon it takes 1.5 days to do,and say its a complicated install, you can take that anyway you like i guess..
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7684543
Chuckle. I'm not sure what they think a "complicated install" is but I wouldn't class it as such. probably 2-3 hours work if you know how to disassemble the dash and get the existing unit out. Even being charitable and hoping they use an RGB input (their photos look like ugly composite video input) it's not that hard.
Seems like a _LOT_ of labour to charge to install an approx $450 NZD device.
Cheers - N
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685438
Yeah, for that kind of money, they can go jump. I realise it's not a quick case of plug 'n' play but that's exorbitant for what the end result is.
Personally, I like the stock AV headunit and it's complemented well by the audio upgrades I've made. However, the GPS solution I've implemented, which is just a MirrorLink device to screen mirror my phone via a composite video output, cost me only $40 if I remember correctly, took me about 20 minutes to neatly install and gives a reasonable result considering it's composite video.
I can only imagine these jokers would want to charge around $500 for even that small effort.
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685493
Heh - I put a mirrorlink unit in my car as well for similar $$$ but then like an idiot noticed that the video screen is locked out when moving :-( Should have checked that first I guess :-)
Plus the bluetooth integration with the built in headunit is now perfect (was flaky until an android update stabilised it a few months ago) so I wouldn't want to have to use the Audio input of the AV (to use mirrorlink for GPS and also have music and podcasts by phone)... Yes I could add a bluetooth bridge and put that into the audio inputs - in fact I did, but it's not as good as the built in bluetooth.
And to my knowledge it's not possible to runthe video input at the same time as the main head unit sound... If it was I would probably look into somehow making the mirrorlink system work while moving.
Cheers - N
Edited by talkiet
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685619
Thankfully in my case, though I've found no signs of tampering with the wiring or the headunit itself, my screen is always on in DVD/TV/AUX mode.
As for running both audio and Mirrorlink together, in my case it works out great because my Sony ZX1 is my actual audio source for all my FLAC files and the Mirrorlink feeds the video. Granted, I don't hear any audio directions from the phone's GPS but then again, I used to read a street directory back in the day while driving so no big deal for this old school'er.
But in your case, you should be able to Mirrorlink your GPS app on your phone but still play audio through the Mirrorlink at the same time, as a compromise, no? That way you will be able to pass audio through the headunit and control that audio with it, in the very least treble, bass and volume controls.
I haven't tried it on mine but since the RCAs are sitting there, I'll give it a crack and report back.
Edited by The Max
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685651
Oh it will work the way you say but I'll miss the steering wheel next track buttons, and the actual quality through the AV input was rubbish when I last used it.
The main issue is the no video while moving and that doesn't look too easy to solve.
Cheers -N
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685904
Nah, the AV input is nice and clean on these vehicles, albeit about 6dB quieter than the CD player. Without knowing the circuit topology, my best educated guess would be it's an unbalanced source as opposed to the balanced internal connectivity of the CD source.
If you believe it sounds horrible, I'm willing to bet that it's your source that's to blame. I use the Sony NW-ZX1 on mine and it sounds as good as a car stereo can be expected to sound. If you're using a phone as your source, generally speaking, phones suck. There are some exceptions to that rule but to my ears, nothing beats having a dedicated player for the task.
Can't explain what happened with my video still functioning while driving though. Maybe I got lucky or there's a clever guy in Japan who modifies the head units internally to prevent the blackout.
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7685962
  • 4 weeks later...
Cheers -N
I can solve watching the video while driving.
Edited by prime-workshopnz
https://www.sau.com.au/forums/topic/462988-for-nz-skylines/#findComment-7699597
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
