I'm surprised I couldn't find a topic in this but I did try.
My V36 2008 with Sat nav came with the rca (composite) plugs in the centre console. I tried a mirabox and my go pro and both have minor picture interference (lines and not overly clear) unfortunately.
Sounds is fine however.
Interference is the same with engine running or just on accessories.
I'm thinking a filter at the input would only help if it was from the source.
Anyone else have this.
I'm either thinking it's not a great connection and to resolve it.
Or tap into the component (rgb) input but this involves the radio out I believe (???). Would this improve the picture anyway?
Or preference would be a filter in the centre console but have my doubts this will help.
Suggestions? I want as clear a picture I can get from a miracast box but don't want to pull the radio out if it isn't likely to help much.
https://www.sau.com.au/forums/topic/463147-video-interference/
No one got any comments? I thought someone would either comment to say they have perfect picture through composite (single yellow rca video) or component (rgb). Or more hoping that others might have had the same interference as me but fixed it..
Key point is it's only the video signal that has interference and it is the same with engine on or off. And only appears when a video source is plugged in (can't see it on black screen).
I was hoping get feedback before pulling the centre console out and checking connections as that's the last resort. I'll likely have to pull the unit out as well which is what I was trying to avoid.
Edited by Pete_Repeat
What you're seeing there is video hum. I have it on mine as well, just haven't been bothered to get my hands on a humbucker (aka isolation transformer) to resolve it. It's highly likely because there's a ground loop happening between the mirrorlink device and head unit.
If/when I do end up pulling my finger out, the plan will be to hardwire it into the cable path within the centre console so that it doesn't take up any valuable space inside the armrest compartment.
  • Like 1
Thanks for your response.
The weird part is that my go pro running off its own battery does it.
So I guess the ground loop must be in the car electrics and the ground of the composite signal (rather than the sources power)
I made a point of using the go pro to isolate the ground of the power source but perhaps I had one of those moments and plugged the usb in as well.... Don't think so but I've done stranger things ha ha.
To be continued tonight.
Let us know then because I was thinking about your mirrorlink device, which is powered by the car. If it's happening on a completely ground-independent device such as your GoPro on battery power, then it suggests my ground-loop theory is wrong.
Are you able to select NTSC over PAL? That is usually the reason for the lines isn't it?
Nope. If it's the wrong colour system, you would have an unstable (as in scrolling) picture as well as no colour.
Reason for this is because PAL has 625 lines of resolution whereas NTSC has 525 lines. So if you have 100 extra or fewer lines than what the display device is expecting, the end result is that it can't lock onto what is meant to be the true end of the field and you get the resulting perpetual scroll.
Then you have the colour subcarrier, which for PAL is 4.43MHz while NTSC is 3.58MHz. If they don't line up, you simply don't get the colour information coming through, hence why it's a black and white image.
I set up my Mirrorlink device to operate on NTSC, since that's the Japanese standard. The herringbone pattern on the screen is definitely video hum though, from my past experiences.
  • Like 1
I'm gonna try the gopro again and make sure I didn't plug in the usb charge by habit... Hope I just messed up and it is ground loops as mentioned.
Was suggested by someone else to measure the outer of the rca input to ensure there is no voltage there, and if not (which it shouldn't) then try grounding it directly to see if that changes anything. Also have one of those ferrite cores to try on the power source..
Hmm. Well you were right. I intentionally got the go pro to isolate power issues like ground loops or any high frequencies while the car is running... But must have subconsciously plugged the power in as well as there are no more lines running on battery tonight.
Interesting part is, the more rca plugged in the worse the interference lines get. Which seems to back up your theory of ground loops huh. And it's no worse with engine running or not so isn't noise due to the alternator.
Looks like a ground isolation or something is in order.
Thanks for the help. I'll report back if I find an easy but cheap solution.
Good humbuckers aren't really cheap. Expect to pay anything around $60 for a mediocre one and around $130 for a decent one.
If you are feeling daring, you could use an audio ground loop isolator but the impedance of the transformer being mismatched to the video source may end up working against you.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
