Hi everyone,im new here and a helpfull assist would be much appreciated..
I have a BNR34Vspec 2001 and facing a problem tat after my car came to a fullstop,after a few seconds my 4wd and A-LSD lights got turn on..after restarting it again everything went normal and it got turn on again after a few second of fullstop..ive checked the resovoir behind the rear boot and fluid are at the max level..ive been tru and read forums but couldnt find a problem that happenned exactly like mine..
I wish to try solving it myself so is there any idea where i can start from?
Help and assist are most appreciated and pls to meet everyone here since im new here and also new to my car
Cheers everyone!!
https://www.sau.com.au/forums/topic/463322-4wd-and-a-lsd-lights-onbnr34vspec/
I did tried finding the spot to read ecu code behind the boot and ended up clueless where its is..tru reading from forums reading ecu codes from boot isnt it apply only for r32 and r33?
Thanks for the reply Hadouken :)
Meathead:u mean after the lights turn on,shut off the and turn on the engine and give it a 1000rpm and see if the lights are on again?ok ill gv it a try by tis evening..if lights still turn on after wat u intruct me to do means theres a TPS failure right?do correct me if im wrong
Thanks for the reply ill update after ive try it out.cheers
Yeah with the engine switched off start it and keep the rpm 1000 and above for a few minutes and see if the Alsd light is on, if it is not and you let it come back to idle does the Alsd light illuminate after a while again ?
You may have a fluctuating idle that goes below normal and sends a low TPS signal to the Atessa cu which will cause the alarm
TPS signal to Atessa on my r33 gtr vspec is 0.3 - 3.7 v if it falls outside of this it will fault.
You could check the AAC valve (under plenum - 4 bolts and a plug) give it a clean and renew the joint. Idle can be adjusted with the screw.
Lots of AAC cleaning threads here in SAU to help you.
If you are not sure get someone else to do it, preferably a friend as a shop will probably sting!
I am not saying this is your problem but it could be. Might be dirty plugs also causing hunting.
Good Luck!
Edited by Meathead
How tf is hunting and dirty plugs related to a 4wd light?[/quote
Hey tf your mouth runs before your brain
You should question other posters in a more civil way.
Tps is directly proportional to rpm which signal inputs to atessa tf
If you could not figure that out then maybe you should just pull your head in tf
Meathead:ive tried as u intructed..like revving above 1000rpm..the lights did not turn on..but as i let go the acceleration my rpm idle show slightly above 1000rpm,is tat a normal?
BTW,wat AAC valve means..?sorry for a noob question..trying to learn as much as i can
Thanks for the reply and point outs..
Not the obvious culprits then.
You should seriously see what fault code is coming up, lots of things can trigger this. ie wheel speed sensors for one.
Regarding far fetched - not at all mate Atessa takes rpm signal also and if the rpm signal fluctuates below a certain range say from hunting caused by fouled plugs it will error. \
Count grantleyish:the 4wd and A-LSD comes on whenever the car come into fullstop...i didnt time lap how long it needs to be driven to alarm the lights to go on..as if itll turn on as long as car stop moving and after few seconds..it came on..
Meathead:yeah,mayb ill take your advise and do a scan just like GTSBoy suggested...but before goin into that i would like to gv a bleed to the attesa system fot any trap air..will update see if this gonna work..cheers everone and thanks
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
