All parts are located in Padstow, Sydney. Shipping will be paid by the buyer.
Contact me via PM.
Item: -5 turbo's with modified actuators by Racepace Motorsport. Currently set at 19 psi. Turbine housings have been opened up to match the gasket. Comes with oil drains also.
Price: $1200
Condition: Great. 10,000 kms worth of use.
A62CF78A-9D5E-4A21-B915-659918E91D9B_zps
93CC027B-E781-4D96-9C57-1E185065EAC7_zps
ECFFBDD1-322B-499B-965A-1FBB7539A9B0_zps
Item: -5 turbo's. Both are blown so will suit a GTX upgrade.
Price: $500
Condition: Dead. Needs rebuild.
4186408A-C43E-4298-9C5C-72F29AFB5387_zps
0F0D2189-0135-4D2F-BAAC-6C29D293608A_zps
3720BC68-0976-417D-947B-E7DB6FB8182D_zps
Item: Front pipe to suit RB30/26. Twin 3 inch into single 4 inch
Price: $300
Condition: Fine
12245609-C229-4D06-85E4-B41B6835E05D_zps
AFB65AB2-E7AE-4060-BCB4-455EDCD1B8D8_zps
Item: SMB rear muffler "diff back". Single 4 inch into twin 3 inch tips.
Price: $350
Condition: Fine.
40E9D4AB-EB99-45F0-A4EA-FEFF234E508E_zps
DDAED056-E301-423A-B944-6F174B8CF92C_zps
C54C0B9C-A742-4437-B470-264EAB74ACBA_zps
Item: Modified Twin Turbo Pipe
Price: $150
Condition: Fine. It has had the "twin turbo" raised bit ground down. It came off an RB30.
C333F06B-AFD9-41D3-AF8A-AC7FAEC6D64D_zps
0F163E90-1B82-4700-8D7B-676058B5FC03_zps
Item: HKS AFM delete pipes
Price: $200
Condition: Fine. Painted black. A few scratches.
17A012C5-47B4-4974-8C9D-B7114A4F5CFE_zps
Item: Modified intake pipes. This has had the narrow point removed.
Price: $100
Condition: Fine.
0EAD7EF7-9879-4F31-98C7-7EB95ACE4536_zps
D4987FF0-9F8B-4228-A9F4-99AB4425B23B_zps
8919EACA-99AB-4963-8649-3E53850B841E_zps
B28C02FA-A457-4989-B9B8-4D21121D1E04_zps
Item: HPI RB26 dump pipes (32/33)
Price: $500
Condition: Fine
1872BBB9-4F24-421F-A3A3-79D59D330C5D_zps
  • 2 months later...
Hey guys,
Both items are located in Georges Hall, Sydney. Buyer pays postage. Contact me via PM.
Item 1: Haltech EGT sensors (6 of) includes weld on bungs
Price: $600
Condition: Brand new.
FC1C1675-C431-4CE1-AC12-BEBBF63D8300_zps
FE6A7E0D-85D3-4D80-855B-7DE9DBF6794E_zps
1EC7A066-BA6E-4F0D-B98A-EA797144B689_zps
Item 2: Holley Dominator 12 - 1800
Price: $420
Condition: 2 weeks of use and 1 dyno session. It came out of GTRNUR's (Ian) car. 98 fuel only.
27D85DE6-CDA9-44AC-A2B7-6B002E66EA3B_zps
62AF46C6-3F90-4B55-B353-910C8C45D63C_zps
  • Like 1
  • 4 months later...
  • 3 weeks later...
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
