Alright Guys,
I would really like to narrow this down for the benefit of all.
Are there ANY series 1 gtst owners out there getting over 400km per tank?
Lets do a quick survey:
- What petrol are you using;
- What mods (if any) and be specific (an exhaust mod can range from cat-back to muffler...);
- Have you reset your ecu since you got the car
- How many kms the car has done when you bought it (or now if ya cant remember)
- I think the boost guage is in a series 1 - what does it read when you hammer the car - 4-5500rpm
- Idle speed when cold, then when warm
That's all I can think of at the moment, when we have a few answers, I will draft up a table and whack it on my website so we can see in a table or something, some similarities.
Here are my answers:
1. BP Ultimate (am on 4th tank in a row now)
2. From what I can tell - only the exhaust system was changed to fit compliance. I did notice that my ecu does not have any LED system on it for Diag mode (?)
3. The second night I got it, disconnected the battery, pumped the brake 6 times
4. 85500 (close)
5. When 4000rpm+ it hits the first bar between 0 and +7. At 5500 and up it goes another quarter to be between the first bar and +7
6. When cold - 1100, warm - 850ish...
Rob
  • Replies 43
srb33 , get your car tuned if you have a pfc or a chip .
if you got a stock ecu not much you can do .
i have a s 1 r33 gtr with pfc and n1 turbos and i get up to 500 k driving around sydney , at least 450 k but i fill up when the red light comes on about 60 -62 lt .
the car runs 11.7 @120 mph and i dont drive like an old woman on a trip i get better .
when i bought the car with stock turbos and stock ecu ( turbo back exhaust ) best i could do was 350 -380k . a good tune not only gives you more power but better fuel economy as well .
i use shell optimax .
- Car - S1 GTS4 (NA)
- BP Ultimate
- Cat back exhaust + Pod Filter
- Yes - Have reset stock ecu
- 65000 KM when I got it, 80,000 KM now
- No boost guage!
- Cant remember idle speed exactly, but normal
- Currently getting about 20L/100KM :S.. Was going to replace O2 Sensor on weekend, but will do next weekend
Cheers :)
chicane
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
