  • 3 weeks later...
Haltech Flex Fuel Sensor with -6 Male fitting $175 with free postage anywhere in the country
The sensor has only been used for around 6-8 months.
The flex fuel sensor will also with plug required to operate.
  • 5 weeks later...
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
