No. Having the same question asked a million times clogs up the search results.
You are left with 100's of small threads that are left with half information because someone didn't have the foresight to search google for the thread that had all the relevant information in it.
There is a large comprehensive size and offset thread on this very site.
What would you prefer? Hundreds of small threads with tiny bits of information. Or 1 large thread with all the information you will ever need?
Well congratulation to you, I'm happy you knew that, I didn't, though now I do. Realize that people who just signed up don't have the experience of the forum like you do.
Those sizes won't fit without guard work. Check the thread that was linked earlier in this thread for what will. Oh and welcome, looks like u have been initiated.
Thanks mate, I did read through it, and yeah I think I have been lol :)
No probs. Like it or not this is the best and most informative skyline forum in the world. 9 times out of 10 you don't even have to ask a question because its already been covered.
No worries mate. So I've decided to get 17x8 with +37 offset for the fronts and 17x9 with +45 offset for the rears. Hoping that will look pretty nice, shipment will take 8 - 10 weeks from Japan so that's why I really didn't want to get the sizing wrong :) Tyres I think will be something like 235/45R17 and 255/40R17
Anything that's 10 inches or wider with offets lower than +15.
XXR or Varrstoen.
Or you scroll down to the massive section about wheels tyres suspension etc.
OR, google "Nismo RWD wheel specs" and buy something with those numbers.
  • Like 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
