Hi all
I am looking for an image file for the following type of Nismo S1 decal:
Have searched for a while now but can't seem to find the correct type. Would anyone happen to know where I could find this? Apparently Nismo do not make the anymore.
It must say: 'S1, S-Tune Concept Engine, Spec1' as per the below photo.
Cheers.
https://www.sau.com.au/forums/topic/464179-s1-s-tune-decal/
There is a R1 logo for sale on YAJ. You could grab that and try to manipulate the R to S if you can find the font :)
Yeah I saw that, they also have an S1 sticker in red (wrong colour), but they want over $130 excl delivery!!
https://www.sau.com.au/forums/topic/464179-s1-s-tune-decal/#findComment-7710887
A good graphic artist/sticker maker should be able to use this image and various pictures you can find of the S1 logo to make you what you want. It may take them some time to get it right but it would be doable.
Ill have a look in my gtr magazines and see if i can find a good shot of the S
https://www.sau.com.au/forums/topic/464179-s1-s-tune-decal/#findComment-7710994
Cheers mate
https://www.sau.com.au/forums/topic/464179-s1-s-tune-decal/#findComment-7711076
Didn't turn up anything useful in the Gtr magazines
Try using this Phil, take it to a good sticker man and he should be able to do the rest. Iron Chef might be able to help with the overall size since he has the R1 concept engine stickers on his car.
http://www.acromann.com/product_info.php?products_id=1338&osCsid=nwnthyjqbsmi
I think the real questions is though, when did you get the S-tune!?
https://www.sau.com.au/forums/topic/464179-s1-s-tune-decal/#findComment-7711474
  • 1 month later...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
