Previous owner was a mature lady owner who imported it and who owned it for around 5 years.
Here are the details:
Interior:
the interior is very clean with only a single slight mark on the rear seat that is almost unnoticeable
Power windows
power steering
power mirrors which fold back into the car so that they dont get damaged
air con only needs regassing
kenwood equalizer and cassette player with a 10 cd stacker in the boot
automatic digital climate control
blitz turbo timer
fully electric sunroof with open/close and tilt up and down feature
all the electrics work perfectly
Engine:
2.0L six cylinder turbo
automatic
145,000 klms with a full log book service history (serviced every 5000kmls)
mechanically a1, drives wonderfully
cat back 3" sports exhaust with a large tip, but everything else is stock
4 brand new brake pads
i have never boosted the car, and it is never flogged
Exterior:
The paint is in very good condition with just the usual little scratches and marks because it is a daily driver, but overall, it is very good paint.
Red/maroon
bodykit with a front bar, side skirts and a rear spoiler (i think the rear bar is stock)
driving lights
17" mags with a chrome deep dish (look really good)
4 near new 235 tyres on each corner
camber adjustment kit so that you dont chew through the tyres
window tint
slimline weather shields that stop the rain coming in the car with the windows down
Now the couple of bad things:
it has a small (10 cent piece size) piece of rust near the back window. Very small though.
There is a little rust on the edge of the sunroof because the rubber just doesn't seal perfectly against the opposite surface. The sunroof does not leak whatsoever though.
This really is a great car, that runs wonderfully and without a problem, but it most be sold! I have got another car and now the skyline just sits in the garage.
The car is registered until March 29th 2005.
The car is located in Murwillumbah which is on the east coast about 30 mins south of the qld/nsw border or about 1 and 1/2 hours south of brisbane.
Price: I'm only asking $11,990 for the car, because it is just sitting there not being driven (i have bought another car)
*updated* Price drop now down to $10,500
Thanks guys
https://www.sau.com.au/forums/topic/46443-fs-92-r32-skyline-11990/
  • Replies 45
The rego is NSW, and i will only be selling it registered.
Yes, i forgot to mention, the suspension is all standard and rides excellently.
I will send through some pictures of the rust hopefully this arvo and also post them up here.
Thanks
Hey im very interested in the car..
Can i get ure number to contact u to come see it..
Iv just sold my car and i have money to spend :D so i am a serious buyer.
or contact me if you could .. i would like to come asap ..
Call aaron on 0413334932
cheers
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
