Hi all,
I'v searched both on this forum and on the internet generally and not found a definitive answer to my set of questions.
There is a lot of discussion out there about the TE37 wheels on teh AWD Sytageas but not much at all about them on a RWD Stagea.
My car is a Series 2 C34 Stagea RWD Auto. I want to fit Volk TE37 wheels but they must have the nice concaved look.
If I go for 17s or 18s, what width and offset of wheel could I use ?
Will that offset on a TE37 have that nice concave spoke look ?
https://www.sau.com.au/forums/topic/464680-volk-te37-on-rwd-what-size/
If installed in the right offset, the TE37 spokes bend inwards going from the outside towards the middle. Thus giving the concave appearance which looks nice... see photos attached
That really depends on the thickness of the hub itself. I've seen quite a few wheels with the same width and offset but instead of concave spokes or a bigger dish, they have just had a bigger hub.. I can't tell you why they do this as it makes it a pain to get a full set or 2 full sets of identical wheels.
The reason why i said this, is the te37 could be one of the brands?
staggea1.jpg?w=1000&h=666
The top car at least is a 260RS and will be AWD
Hey Bob what were your track wheels? i remember them being 3 piece and multispoke. Can you post a picture? I really liked them.
Bought them second hand off a drifter - can't remember the brand sorry...
Here ya go - 5 minutes on Google and here's what you are after - they are called TE37 Ultra Evolution Track edition (with what they call "inverted" spokes) - nothing to do with offset - they are available in a range of sizes and offsets. I suspect they will cost an arm and a leg each:
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=TE37ULTRA-TE
If you had bothered to click on the Link to Rays Engineering that I gave you you will see that this statement is incorrect (as is your statement that you know the model of wheel you are after). It is the particular model of TE37: "Ultra Evolution Track Edition" that gives them the inverted spoke look that you are after - nothing to do with offset - as i have already told you they are available in a full range of offsets ALL of which feature the "reinverted spokes".
17 or 18 x 8in or 9in will fit. For offset I have no idea for your car - for mine it requires different offsets front and rear.
According the the web site they only come in a 20" rim size for the ultra track edition and 19" and 20" for the Ultra
Yes quite right. Which confirms my theory that the wheels on the 260Rs cars above are Varrstoen copies (not forged but cast) which do come in 17 18 and 19 inch. Others making similar knock-offs include Koya and Rota.
I did bother to look at the link.
Reading through it and finding that, the "track edition" is not available in rim size 18" confirmed to me that it is not the only edition that can give the inverted spoke look.
The photos below are of a car which has Volk TE37 in 18" ... not replica. These photos show the wheels to have that inverted spoke appearance which I am after.
Edited by ceejay
I found a couple of the TE37SL variants have that look.
That is right Sir. That is exactly what I am saying too. There are several of the TE37 versions that have the inverted spoke appearance.
The spokes look more and more concave as the outer edge of the rim moves further and further towards the outside of the car, compared to the position of the hub. negative offset or the smallest positive offset.
What I want to know is, say for 17" and 18" wheels, (never mind what brand or style) what is the width and maximum offset usable, which will bring the edge of the wheel closer to the outside of the vehicle but still not cause fouling with the wheel arches.
Edited by ceejay
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
