Yes mate I know. That was my first time I've tracked the car and also first time on south circuit. I went to learn the car and have some fun. I definitely have alot of learning to do but I think I did ok for my first time, not the easiest car to learn on haha
I got a 1:09, i know not very good, I think I'll run less boost next time and focus on track work. A few guys there were great support, I appreciated that!
Hey Ben did the boost controller give the error again after we had a look at it??
Did really well mate once you get comfortable with the car times will drop
Nick
Nick
Hey Nick,
Thanks again for the pointers and help. Funny enough it went back to normal, no errors came back but then came the next issue. I was running 23psi that day but in my last session it was constantly spiking to 30psi. I noticed from the sound of the gates and the power increase. I backed off and brought it in. It made some funny noises momentarily and I drove it home. I'll need to get it looked at
27 minutes ago, HKS28R said:
Hey Nick,
Oh wow yea get that checked don't want that happening all the time
As long it drove home with no issues is the main thing
Who do you guys recommend for an honest Sydney tuner that deals with track cars? I've been told about the bloke up the coast but I'd like to know if there's anyone else local
Pulling 1:09 on your first track day is pretty good man. I thought you were doing well. See you next time hehehe.
  • Like 1
Was going to ask how that noise went.
Hopefully it's nothing major.
But, if it is.....
Still get tp drool over just looking at your car.[emoji7]
  • Like 1
But, if it is.....
Haha thanks. Well it drove home ok, i didn't let it come on boost. Going to get it looked at, praying nothing is wrong.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
