Yes mate I know. That was my first time I've tracked the car and also first time on south circuit. I went to learn the car and have some fun. I definitely have alot of learning to do but I think I did ok for my first time, not the easiest car to learn on haha
I got a 1:09, i know not very good, I think I'll run less boost next time and focus on track work. A few guys there were great support, I appreciated that!
Hey Ben did the boost controller give the error again after we had a look at it??
Did really well mate once you get comfortable with the car times will drop
Nick
Nick
Hey Nick,
Thanks again for the pointers and help. Funny enough it went back to normal, no errors came back but then came the next issue. I was running 23psi that day but in my last session it was constantly spiking to 30psi. I noticed from the sound of the gates and the power increase. I backed off and brought it in. It made some funny noises momentarily and I drove it home. I'll need to get it looked at
27 minutes ago, HKS28R said:
Hey Nick,
Oh wow yea get that checked don't want that happening all the time
As long it drove home with no issues is the main thing
Who do you guys recommend for an honest Sydney tuner that deals with track cars? I've been told about the bloke up the coast but I'd like to know if there's anyone else local
Pulling 1:09 on your first track day is pretty good man. I thought you were doing well. See you next time hehehe.
  • Like 1
Was going to ask how that noise went.
Hopefully it's nothing major.
But, if it is.....
Still get tp drool over just looking at your car.[emoji7]
  • Like 1
But, if it is.....
Haha thanks. Well it drove home ok, i didn't let it come on boost. Going to get it looked at, praying nothing is wrong.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
