e_Dog Posted July 22, 2016 Share Posted July 22, 2016 Hi all, A/C fuse keeps blowing. Several auto eleces have had a look and not been able to fix. Last one is know saying that the compressor is causing a short and needs to be replaced and partly because i dont feel like replacing it just to check he's right plus i cant actually find a second hand one, means im wondering if theres any way to know this is the actual cause and if theres any way it could be fixed without replacing. Bit more info; 10amp fuse blows nearly straight away, 20 amp lasts about 15-20 minutes. Clutch is engaging, everything is working fine when the fuse is still functional. Help please, i paid dollar bills ya'll to have this a/c installed (engine swap, had no ac originally) and havent had fully working ac for 2 years Link to comment https://www.sau.com.au/forums/topic/465930-ac-compressor-causing-short-rb25/ Share on other sites More sharing options...
t_revz Posted July 23, 2016 Share Posted July 23, 2016 Fit 10A fuse. Disconnect compressor. Turn on Ac and see if it blows. Or go for a short drive like this to see if it lasts. Link to comment https://www.sau.com.au/forums/topic/465930-ac-compressor-causing-short-rb25/#findComment-7759936 Share on other sites More sharing options...
e_Dog Posted July 23, 2016 Author Share Posted July 23, 2016 20 minutes ago, t_revz said: Fit 10A fuse. Disconnect compressor. Turn on Ac and see if it blows. Or go for a short drive like this to see if it lasts. Good idea, will do now. Link to comment https://www.sau.com.au/forums/topic/465930-ac-compressor-causing-short-rb25/#findComment-7759937 Share on other sites More sharing options...
MrStabby Posted July 23, 2016 Share Posted July 23, 2016 Measure the resistance of the magnetic clutch. Should be around 3.5 ohms. If it's much less then there's a short. Link to comment https://www.sau.com.au/forums/topic/465930-ac-compressor-causing-short-rb25/#findComment-7760034 Share on other sites More sharing options...
