found something i want more so i am parting out or selling as a whole to fund it.
Complete car in bits. no SA rego would need ID check, not defected. PPSR available .
Prices as follows or 0416 580 223 for more information
will do deal for multiple parts, complete rolling shell or even complete car.
13669091_10155186703734896_2633344405020
13819603_10155203457914896_404478025_n_z
13817056_10155203457919896_1111018039_n_
Motor
RB20DET GTS4 top rebuild motor. Head cleaned and faced new valve stem seals full OEM Nissan gasket set etc. 1000
Steel wheeled RB20 turbo 50
starter 50
AC setup 100
P/S pump 80
alternator 50
coilpacks 100
loom 150
ECU 100
igniter 50
stock IC + pipes 50
allow GTR engine brackets AWD 60
AWD nissan engine mounts 40
green label AFM 100
Shell (minor rear end damage as pictured, boot still opens and closes. some rust in places)
semi bare shell 500
headlights 200
indicators 80
uncut front reo 120
guards 100
bonnet 100
Doors 50 each 200
4 door mirrors 80
boot 50
rear bar 50
taillights 150
front bar 80
2.5" turbo back cannon exhaust $100
interior
front seats 50
rear seats 50
dash 200
floor mats 50
stereo: speakers/headunit 100
sunroof/lining 150
a pillar 20
center console 50
parcel shelf 20
cluster 150
climate control 50
Driveline/suspension
R32 GTR box 1000
HD clutch+ flywheel 100
type M brakes 250
GTR cradle with diff 500
gtr GB crossmember 50
front prop driveshaft 80
driveshaft 150
5 stud 100
front LCA pair 30
6 bolt GTR drive shafts pair 200
KYB GTR suspension 200
engine crossmember 50
front drive shafts 150
https://www.sau.com.au/forums/topic/465932-sold-r32-gts4-sunroof-sedan/
  • 4 weeks later...
There is also someone looking for a sedan rolling shell you may be able to flog the whole car off to.
http://www.gumtree.com.au/s-ad/sydney-city/cars-vans-utes/wtb-r32-gts4-shell-or-complete-car/1119896717
Good luck
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
